4 minutes ago, Jim Feeley said:
I'm not planning on buying this (or anything from Behringer). But this is coming.
https://www.behringer.com/behringer/product?modelCode=0603-AFE
Audio on the YouTube video isn't great...
Liked the early expletive and the dig at the director/producer
Thanks for pointing it out Jim - I'd not have seen it for months I expect!
Jez
  • Jim Feeley changed the title to Behringer's FLOW 4V field recorder for $279 USD
20 minutes ago, PMC said:
For under $300 USD
Finally something that goes for what producers *think* sound gear costs. And seems super reliable and great without having to worry about turning knobs, because it will be perfect automatically.
On a more serious note, I think the race to the bottom is heavily promoted in this video. And it’s just depressing with the way things are already going at this time.
“Yeah, let’s get this and some wireless from AliExpress and we can have the DP take care of sound and gaffer duties, (and apparently catering as well).”
IDK, maybe it’s time to retire…
By now I've done a lot of work with the Beh. Flow8 mixer, which came along at a very fortuitous moment for me.  It is a very clever box that can do a great many things well in a tiny footprint (very carry-on-friendly) with, this being a Behringer product, next to no documentation or support.  The Flow 8 has been used in what are the most fraught moments of my work with the dance company I work for: full up rehearsals with the full company, cameras and famous musician guest stars.  I'm running a PA with basic effects, IEMs, multitrack recording and playback from a box about 5" x 7".  I'd guess this new recorder departs from the same technology Beh developed for the Flow8, and figure they aren't done yet (like a long-awaited replacement to the X32 mixer).  As with all things Behringer/Midas/Music Tribe, if you are lucky and get a good one then off you go on the cheap.  (The Flow8 sounds quite good.). If you have a problem, need service, want info other than what the online community can help with: you are hosed.  Anyone used to SD / Zax level of support (especially over the phone) would need to adjust their expectations drastically: you are on your own.  I bet this recorder will be very popular, and I bet that pro users will be smart enough to know that they'd better be packing 2 of them on any gig of consequence.
I have no idea who such a device is for... not so much for sound engineers. The inappropriately chosen red color is probably the least of it. SD card without any protection. Power supply via USB-C. To start recording, you have to press REC twice. No gain control. I don't see any possibility to edit metadata. Unfortunately, this didn't work at all
I sure hope the audio in that video isn't representative of the audio quality in the recorder.  If it is, it sounds like it could be those touted DACs ... I remember the Zoom H1 (a $100 'digital notes' style recorder) sounding that way.
But for my money, the audio sounds heavily filtered in post.  It's EQed for sure, and there's lots of signs of AI noise cleanup.  I wonder if they've covered the voices with an Exciter plugin or something like that.  I've noticed that inexperienced dialogue editors who come from the music world like to throw those plugins on by default ... I think they are expected as part of voice processing.
Whatever is going on, I agree with Jim ... the audio doesn't sound great.  Like Johnny says, it sounds like the race to the bottom.
I wonder how they are pulling 4 channels of audio over a single XLR connector for the expansion box given AES usually can only carry 2 over a single XLR.
All in all this seems like a very cool product, basically "a modern Zoom F4"!
I've been hammering on for years "where is the update to the Zoom F4?" (a "F4n"?)
As I'd have loved to get a Zoom F4n!
Because the F4 is not a true update to the F4, and the F4 had various benefits I liked over its big brother F8
"We skipped the built-in battery on purpose. Fixed battery systems age quickly, while USB-C stays flexible and can be easily adapted to what you already own.
Two recessed USB-C ports provide redundant, hot-swappable power from any USB-PD source, including power banks. A compatible power supply is included."
That's crazy they don't have hirose to power this, or even a DC jack, but instead just USB!
May be an image of text that says 'behringer ::::FLOW4VIO :FLOW4VIO :FLOW 4VIO'
Image_BE_0606-ADZ_FLOW-4VIO_Media-Left_2
Image_BE_0606-ADZ_FLOW-4VIO_Media-Other1
https://www.behringer.com/behringer/product?modelCode=0606-ADZ
The  optional FLOW 4VIO that adds to the recorder four additional dual-stage microphone preamps and two independent headphone outputs is pretty cool though (the combo setup would however be heavier than a Sound Devices 833, higher power consumption as well)
https://www.bhphotovideo.com/c/product/1819630-REG/behringer_flow_8_8_in_digital_mixer_bluetooth_audio_app.html
US$199??? That's crazy cheap even for Behringer!
At least we've got the quickstart guide for the Flow4V already which is fairly extensive: https://cdn.mediavalet.com/aunsw/musictribe/WZN169UOxE-CxMe1pln0ww/HBUz2xY-m06IJalUFZotCg/Original/QSG_BE_0603-AFE_0606-ADZ_FLOW4V_4VIO_WW.pdf
I thought this was interesting:
May be an image of text that says 'SD Recording Channels 1-4 Source 5-8 Local Inputs 1-4 9-10 StageConnect Inputs 1-4 11-12 AUX IN, Stereo 13-14 USB/Bluetooth, Stereo 15-16 Talkback, Stereo Main Mix, Stereo During playback, each recorded channel is routed to its corresponding input channel on FLOW 4V. The USB/BT channel can play back either the recorded USB/ Bluetooth stereo signal or the recorded Main Mix, selectable in the SOURCE menu. The AUX IN channel can be beset to play back StageConnect inputs 5-6 or 7-8 coming from FLOW 4VIO.'
Because wait a second... can it record even more than 10 tracks???
Exactly. And even buying two of these will still be dirt cheap.
And even you have "a pro recorder" you should always have a spare with you anyway (no matter if it is say an old 744T or a cheapie Zoom F8, or whatever)
I expect at launch this recorder will have a lot of shortcomings, but will be very interesting to revisit the Flow4V in a couple of years' time, once it is on v2.0 firmware (or even v3.0 or whatever it is up to).
Heck, recall way back to say the original launch of the MixPre series vs what it is today after all the firmware updates! Is 100x better.
5 hours ago, inspire said:
Tascam is going to have to drop their prices a lot to be competitive.
But I'm kinda expecting that, Tascam has often had a big gap between launch RRP and street prices a few years later. (such as the DR60D / DR680 / HS-P82 / etc)
Would be their own proprietary digital system? Not unusual for a stage box to have multiple channels running over a single cable.
16 minutes ago, The Documentary Sound Guy said:
Behringer has its own proprietary competitor for Dante.  All digital, multiplexed.  Though I noted that the range was short, so it sounds like it is somewhat limited over XLR.
Surprisingly the video said it is only 5m over a standard mic cable, but is longer with a DMX cable. And they've got range extenders too they mentioned in the video.
" I think the race to the bottom is heavily promoted in this video. And it’s just depressing with the way things are already going at this time."
I have to laugh out loud at this statement. I remember when I was the chief online editor at a production house in the late 80's and had Sony 1 inch machines, Beta SP, Grass switchers, routers, DAs VPE editors, a $58,000 Abacus A53 with warp ( yes a $58k box that only did one thing, kiddos), Paint Box, (anyone miss chasing SC phase?) etc., etc... and when the Avid Media Composer came out we scoffed at it.
Four years later when it became good enough to call it 'near online quality' we bought one with the pizza box DVE for $110,000.
Then the snot-nosed kids with a Mac laptop and a miniDV Camcorder started eating into the business. Not for broadcast but for industirals.
Now, with Adobe Creative Suite, we can do for pennies what used to cost hundreds of thousands of dollars in dedicated boxes.
But wait, it gets worse. Now I am losing After Effects clients to a new wave of snot-nosed kids using Sora 2.
Change is constant and inevitable.
if I was in the market for a backup location recorder I would pick one of these up. Okay, I get that It's Behringer but It's priced as an expendable, LOL.
"That was me!"
The Documentry Sound Guy, you owe me so much in lost revenue, LMAO. And I owe the guy who shot and edited on film who I took work away from.
Frankly, can I call you frank, I am only generating half of the revenue now than what I generated before COVID. Very depressed job market, producers asking for a long list of gear for a low cost or 12 hr days at a 10hr rate, etc. If I was just starting out I wouldn't buy any acquisition gear. I'd focus on computer generation media and be THAT snot-nosed kid.
On 1/16/2026 at 5:50 PM, Olle Sjostrom said:
We’re not the audience obviously, but…
I'd be interested to know how many on this forum will work with this type of equipment in the coming months.
They'll capture the up-and-comers.  And if it sounds good, the up-and-comers will keep using it when they are just comers.
So the question is ... do the recorders sound like video (i.e. crap), or are the recorders fine and the video is a victim of over-exuberance in post?
One of us needs to actually get our hands on it so we can listen to it with experienced ears.  And if it sounds ok?  Yeah, we'll see and hear them in the field, just like Zoom.
If there is a need I will work with whatever tools I can get, especially since this sort of new tech makes what I already have much harder to sell.
Here's Curtis Judd's first look at it. The interface seems clunky, but the preamps have potential. I personally detest Zoom F8's sound....can spot it from a mile away. (Yes i know the producers do not hear the difference, i  don't care - I do. And it's me hearing the tracks at the mix )
This, if similar to Behringer Wing,  which i worked on, will sound much more natural.
the first sound quality test at 21 minute mark, the second one (with a 150 ohm resistor) at 46 minute mark.
Clunkfest!
also.. what’s up with the huge pan knob? If they’re somewhat targeted towards video recording, they should know panning is not even really necessary… not sure even podcast would be interested in that stuff..
Also, on a darker note, I’m kind of happy Jeff didn’t live to see the day Behringer entered our business. RIP
