dgirtsman Posted August 21 Report Posted August 21 It's getting harder to find the exact models from the SD approved media list. I'd be interested in hearing where people are getting their media from and what is working well for them. Thanks! Quote
Axel Mishael Posted August 21 Report Posted August 21 It used to be any reliable media company within 90mbs-150mbs per second, not more than that, Lexar, Kingston, Sandisk, all worked fine. Quote
Philip Perkins Posted August 21 Report Posted August 21 Still using SD branded cards...(664 @ 12tr x 24/48). Quote
edward chick Posted August 22 Report Posted August 22 I have been using SD Brand cards for ten years or so. Never failed me. Quote
OB1 Posted August 22 Report Posted August 22 SD brands all day long, no issues. If you're weary, just run both slots with a known "approved" CF as backup. Let slot 2 be your tester. I'm still to run into a DIT that doesn't have a CF reader. Quote
JFtaper Posted August 25 Report Posted August 25 you gotta test them yourself we tested a bunch of different cards with the mixpre series and many failed when the write rate was maxed out https://taperssection.com/index.php?topic=191314.0 the mixpre series was quite picky relative to say zoom, but not as bad as some tascams if you follow that thread to the end there is some discussion on using CPDT to look at random write speed as a measure of stability Quote
Jim Feeley Posted August 25 Report Posted August 25 Ya, I'm using Sound Devices cards. And ya, I'm bummed about their high prices. Like US$245 for a 64GB card. (I should buy a couple more cards). But I'm taking a better safer and poorer than sorry approach. 😞 https://www.trewaudio.com/product-category/expendables/expendables-media/ Would love to hear from SD an update of any sort on this topic... Even if it's a "we're not testing SD cards for 6-series and 7-series recorders anymore." Quote
Tim Norris Posted August 27 Report Posted August 27 On 8/25/2026 at 11:06 AM, Jim Feeley said: Would love to hear from SD an update of any sort on this topic... I recall talking to Sound Devices about this a couple years ago... the answer seemed to be "if it's not on the bad list, it's probably good". No one is testing cards, no one is reporting bad cards, and no one is keeping track. From a tech friend... beware of low priced cards. They are likely downgraded larger cards that did not pass testing or have been recovered from the reject bin at the factory. Only buy branded cards from trusted sources. Cheers, Tim Quote
