Super sticky medical type tape?
berniebeaudry
I've been searching for over an hour to no avail.  There was a mention of a really good medical tape product that wasn't any of the usual products.  I can't remember what it was called.  Does anyone remember it and what it was called?
Thanks for your help!
Bernie
There's Transpore which I use often. There's also tape called Medipore which they use to place over IV sites. It's hypoallergenic and perforated so you ca place over a lav. There's various other kinds of medical tape, but those are the ones I use most often.
Are you thinking of the Leuko tapes?
I use Leuko Sportstape http://www.elastoplastsport.com.au/Products/ProductDetail.aspx?IdDataSource=19
works great. The 3.8cm x 13.7m roll - code 76012. Beige colour is stickier than the white but the white can come in handy sometimes. It uses zinc oxide adhesive but I've only ever seen one girl have a reaction to it from the countless people we mic up every day. I guess she had very sensitive skin.
Place the lav in between two pieces, like a sandwich.
Not sure where you can get it in the US though but its readily available in chemists/pharmacys here in Australia.
Photo is 76015 but you get the idea.
Cheers
Peter Mega
I'm a bit late, but try searching Google on "sports tape" and "athletic tape." Brands like Mueller, Kinesio, and others make all sorts of stuff. Or drop by a big sports store and check out the various adhesives, removers, and other stuff. I use a bunch of sports tape and stuff when wiring athletes...
I was told by a nurse once to try pink tape.  That's what they called it.  Said I should be able to get it from any medical supply place.
Pink tape is SUPER sticky. Would work great but not sure if it would leave a residue on your lav heads or cables. Works great on skin, but can be painful taking it off.
  • 1 month later...
