Cinela
Richard Ragon
I've been utility/2nd boom on a show where the Cinela mount is used with two MKH50. One of the mounts has the old metal spring wire and the other has the newer thicker plastic isolator. For regular booming with a typical light weight foam windscreen we usually use the mount with the thin wire suspension, but then we opt for the newer plastic suspension to compensate for the extra weight if we need to add a furry. Both work really well.
I really wish they would make one with an adapter for a zeppelin
Stephane
Thank you for the input Stephane. I should get one for a 416 and Koala fluffy really soon then.
