Solid Goldberger Posted May 9, 2011 Report Posted May 9, 2011 Hello Friends, I'm looking to make some DC power cables for bag use (I've finally decided I'm sick of spending the time rewiring my BDS every time i switch my wireless from my Fusion bag to my 552 bag, and vice versa, but the thought of buying all those cables again makes me woozy). However, i can't find any definitive information about the specs of various connectors used on all my various gear. Specifically I'd like to find out what is the connector type/brand is for: Remote Audio BDS outputs (locking DC connector, straight and right angle) Lectrosonics SRa/SM Battery Eliminator/T1 power inputs. (locking DC connector, straight and right angle) Hirose 4-pin for 552/mixer power input (Obviously made by "Hirose", but which one exactly?) I'd also love it if you could send me a link to your favorite sources for these. Further, do you have a favorite thin (but sturdy) DC-friendly cable for this type of use? Something flexible but robust would be great. Thanks in advance! e. Quote
Matt Mayer Posted May 9, 2011 Report Posted May 9, 2011 Ethan, The BDS output, iirc, is a Switchcraft 761K. The right angle version is only available from Remote Audio, unless someone else has come up with one. Switchcraft has live updated stocking info from their dealers, Go to this page and click on "Check Stock" for the appropriate part number: http://www.switchcraft.com/productsummary.aspx?Parent=479 The Hirose is the HR10-7P-4P. Make sure to get the good one with the metal collet, not the HR10A with the crappy black rubber strain relief. I would just google the part number, but you can get them at Newark, DigiKey, Mouser, etc. Dont have any batelims, so I am not sure about the Lectro connectors, but I think they use S760K, locking, 2.06mm center pin, Quote
Solid Goldberger Posted May 9, 2011 Author Report Posted May 9, 2011 Matt, Thanks for the info. Dont have any batelims, so I am not sure about the Lectro connectors, but I think they use S760K, locking, 2.06mm center pin, Can anyone confirm this? Would love to be sure before I go and order them. e. Quote
Wyatt Tuzo Posted May 9, 2011 Report Posted May 9, 2011 Matt, Thanks for the info. Can anyone confirm this? Would love to be sure before I go and order them. I dont know the exact connector or pin diameters off the top of my head, but you can go into Gotham Sound and they will sell you 6ft, unterminated, molded right angle versions at a good price. I make all of my cables from those. They are akin to the Lectro 21472. I usually buy my switchcraft connectors and Hirose from them as well.... Wyatt Quote
Solid Goldberger Posted May 19, 2011 Author Report Posted May 19, 2011 One more connector I'm looking for. Is there a female version of the Switchcraft 761K (BDS) connector that can be connected to a cable? For example, if I wanted to make an BDS power cable extention, or a splitter? If such a connector doesnt exist (outside of a panel-mount version) anyone have an idea how a splitter could be made simply? Looking for one more output from my BDS! e. Quote
Derek H Posted May 19, 2011 Report Posted May 19, 2011 Good question solid, I've been looking for the same thing. switchcraft doesn't seem to make one.. Maybe a chinese version molded on a cable..? If no avail then I've been wondering if the panel mount version would fit in a 1/4 in connector body. Let me know if you find anything Quote
Jack Norflus Posted May 19, 2011 Report Posted May 19, 2011 If such a connector doesnt exist (outside of a panel-mount version) anyone have an idea how a splitter could be made simply? Looking for one more output from my BDS! I don't see why you can't make a Y cable. Use an 761k connector and Y off of that. Quote
ProSound Posted May 19, 2011 Report Posted May 19, 2011 Remote Audio Makes a Y input and Output cable I think its listed on the website if not just call Quote
Glen Trew Posted May 19, 2011 Report Posted May 19, 2011 The BDS output connector has a 2.5mm center pin, and was chosen to be incompatible with the more commonly used 2.1mm output plugs to prevent accidental cable reversals, etc. For the same reason, the BDS outputs also require a longer shaft than, for example, the plugs that power Lectrosonics devices. The BDS output connectors do not become active until the longer shaft is pushed all the way in. The price of the Remote Audio BDS cables was significantly reduced, so it may be less expensive than you remember. Glen Trew Quote
RScottATL Posted March 2, 2013 Report Posted March 2, 2013 Edited out. Gave some 2.5mm x 5.5mm plugs. Quote
RScottATL Posted March 7, 2013 Report Posted March 7, 2013 http://www.remoteaudio.com/cables_adapters/power/xlr/ This link references the Switchcraft S760K and states that the cable is capable of powering Lectrosonics LZR type units such as the SR series receivers. http://www.mouser.com/ProductDetail/Switchcraft/S760K/?qs=Z0CQwBkL9d0b%252by2xBlPCrw%3D%3D&gclid=CPmg_ry567UCFQmxnQodBlsAHA This is a link to the part at Mouser, was 4.67 when I checked. It looks like the right part, but I'd order one and check it out before going whole hog. The 502-760K part is a 2.5mm ID plug, which does not match. Quote
Boomboom Posted March 7, 2013 Report Posted March 7, 2013 For Lectro you gotta use 2.1mm internal 5.5mm external plug. That'd be the S760K. (With the "S"). http://ca.mouser.com/Search/m_ProductDetail.aspx?Switchcraft/S760K/&qs=/ha2pyFaduiOYRbiiGBl52bBH94AfMUskf5jpQLNa08= Quote
RScottATL Posted March 7, 2013 Report Posted March 7, 2013 http://www.tensility.com/content.asp?pgid=1264 Tensility looks like they have a locking, right angle version of the S760K. They have three flavors: 10-00114 -- Two connectors wired together, shielded (single jacket), 78" 10-00115 -- One connector wired stripped and tinned, shielded (single jacket), 78" 10-00116 -- One connector wired stripped and tinned, siamese side-by-side style double jacket, 78" Those connectors are specced at 2.1mm ID, 5.5mm OD. The only Lectro reference I could find was in inches (0.076" ID, 0.215" OD) which doesn't EXACTLY line up, so who knows if it works or not. Edit: I found some off-brand CH20 power supplies for Lectro receivers that list their DC connector as 2.1mm ID, 5.5mm OD, so I suppose 2.1x5.5 is good. Anyone know depths for the parts? Or, get the Lectro model at B&H: http://www.bhphotovideo.com/c/product/663927-REG/Lectrosonics_21586_PWR_CBL_LCKNG_LZR_TINNED.html Straight LZR 6' $7.50 http://www.bhphotovideo.com/c/product/623385-REG/Lectrosonics_21746_21746_Power_Cable_12.html Right Angle LZR 12" $3.61 http://www.performanceaudio.com/buy/Lectrosonics/21747/14522?gclid=CPzB7O_F67UCFQODnQodrHsAZw Right Angle LZR 6' $7.58 Who knew? Factory connectors at reasonable prices? Quote
Boomboom Posted March 9, 2013 Report Posted March 9, 2013 I got the Lectro's like the ones at B&H and also bought the Switchcraft connectors and even if the specs aren't exactly 100% the same I can tell you everything's fine. I had the same concerns you have at first... Didn't know about the Tensility cables; they look nice ! thanks for the link... Quote
MattinSTL Posted July 12, 2014 Report Posted July 12, 2014 http://www.tensility.com/content.asp?pgid=1264 Tensility looks like they have a locking, right angle version of the S760K. They have three flavors: 10-00114 -- Two connectors wired together, shielded (single jacket), 78" 10-00115 -- One connector wired stripped and tinned, shielded (single jacket), 78" 10-00116 -- One connector wired stripped and tinned, siamese side-by-side style double jacket, 78" Those connectors are specced at 2.1mm ID, 5.5mm OD. The only Lectro reference I could find was in inches (0.076" ID, 0.215" OD) which doesn't EXACTLY line up, so who knows if it works or not. Edit: I found some off-brand CH20 power supplies for Lectro receivers that list their DC connector as 2.1mm ID, 5.5mm OD, so I suppose 2.1x5.5 is good. Anyone know depths for the parts? Or, get the Lectro model at B&H: http://www.bhphotovideo.com/c/product/663927-REG/Lectrosonics_21586_PWR_CBL_LCKNG_LZR_TINNED.html Straight LZR 6' $7.50 http://www.bhphotovideo.com/c/product/623385-REG/Lectrosonics_21746_21746_Power_Cable_12.html Right Angle LZR 12" $3.61 http://www.performanceaudio.com/buy/Lectrosonics/21747/14522?gclid=CPzB7O_F67UCFQODnQodrHsAZw Right Angle LZR 6' $7.58 Who knew? Factory connectors at reasonable prices? Click these links... Prices up 300 to 700% since last year :-( I have a locking right angle power output on my BDS. Know what those are? Quote
soundtrane Posted July 12, 2014 Report Posted July 12, 2014 I have been using the Tensility cables with moulded right angle connector for Lectros to go with my custom-made DC distribution unit since last year. Works fine. If you need it i can look up the exact part number and write back. Quote
David Marien Posted July 17, 2014 Report Posted July 17, 2014 I have been buying my hirose connectors from CCS (connector Cables Specialists) in the UK http://ccsukltd.co.uk/index.php?route=product/product&product_id=121993 They deliver worldwide reliably. These are NOT genuine Hirose connectors but cheaper copies. I know some of us may doubt the quality of them, but I have been using them in all of my DC cables, as well as the sockets in my DIY distro for a couple of years and I am yet to have a single problem. They are of course compatible with the genuine hirose sockets found on cameras. At about 5 times less than the price of original hirose (even more for us in Australia), they are well-worth considering. Quote
berniebeaudry Posted July 18, 2014 Report Posted July 18, 2014 One more connector I'm looking for. Is there a female version of the Switchcraft 761K (BDS) connector that can be connected to a cable? For example, if I wanted to make an BDS power cable extention, or a splitter? If such a connector doesnt exist (outside of a panel-mount version) anyone have an idea how a splitter could be made simply? Looking for one more output from my BDS! e. I took one output from my BDS and wired it to four right angle coaxial connectors that power my four Lectro 211s. The junction is in a small plastic box. Its been working well for about four years. Quote
Simon Hayter Posted July 18, 2014 Report Posted July 18, 2014 I have been buying my hirose connectors from CCS (connector Cables Specialists) in the UK http://ccsukltd.co.uk/index.php?route=product/product&product_id=121993 They deliver worldwide reliably. These are NOT genuine Hirose connectors but cheaper copies. I know some of us may doubt the quality of them, but I have been using them in all of my DC cables, as well as the sockets in my DIY distro for a couple of years and I am yet to have a single problem. They are of course compatible with the genuine hirose sockets found on cameras. At about 5 times less than the price of original hirose (even more for us in Australia), they are well-worth considering. Nice find, thanks. Quote
B_Van_Deusen Posted September 22, 2015 Report Posted September 22, 2015 One more connector I'm looking for. Is there a female version of the Switchcraft 761K (BDS) connector that can be connected to a cable? For example, if I wanted to make an BDS power cable extention, or a splitter? If such a connector doesnt exist (outside of a panel-mount version) anyone have an idea how a splitter could be made simply? Looking for one more output from my BDS! e. Hi, I am also looking for connectors like these, i find plenty of the 2.1mm Id pin x 5.5 online everywhere, but i can't seem to find the Female 2.5mm ID pin version. I have bought a few of these non-locking connectors at one of the NYC production sound stores, but i'd like to find them cheaper (i know they are 2.5mm because the 2.1mm bulk connectors i ordered from china don't fit the legit ones I bought =). All i seem to find is the terminal connectors online. Solid were you ever able to find a good solution for this connector? Best, Brett Quote
Matt Mayer Posted September 22, 2015 Report Posted September 22, 2015 (edited) Long Shank/BDS: http://www.switchcraft.com/Stock_Check_Simple.aspx?Part_No=761K Regular Shank: http://www.switchcraft.com/Stock_Check_Simple.aspx?Part_No=760K Edited September 22, 2015 by Matt Mayer Quote
