Fiftyfoot Posted June 21, 2011 Report Share Posted June 21, 2011 would I best choose to go from XLR to RCA? I'm looking to make cables to go out from a Wendt mixer, line in to a Tascam HD-p2. (Tascam's XLR's are mic only) Thanks, Scott Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted June 21, 2011 Report Share Posted June 21, 2011 would I best choose to go from XLR to RCA? I'm looking to make cables to go out from a Wendt mixer, line in to a Tascam HD-p2. (Tascam's XLR's are mic only) Thanks, Scott You can't go wrong with Canare L-2E5, 2 conductor shielded. Split the shield into 2 leads, tin them and attach to pins 1 & 3 to unbalance the connection. Eric Quote Link to comment Share on other sites More sharing options...
Fiftyfoot Posted June 21, 2011 Author Report Share Posted June 21, 2011 You can't go wrong with Canare L-2E5, 2 conductor shielded. Split the shield into 2 leads, tin them and attach to pins 1 & 3 to unbalance the connection. Eric Great, thanks. Was wondering about that extra pin. Scott Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted June 21, 2011 Report Share Posted June 21, 2011 Great, thanks. Was wondering about that extra pin. Scott If you have an RCA to RCA cable just cut off one end and attach the female XLR. Going from a balanced connection to an unbalanced connection you have to connect pins 1 & 3 to ground to unbalance the circuit. Splitting the shield is a lot easier than connecting the ground to pin 1 and wiring a jumper to pin 3. Eric Quote Link to comment Share on other sites More sharing options...
Derek H Posted June 21, 2011 Report Share Posted June 21, 2011 Eric, Isn't there also the scenario where you have active balanced outputs (like on the 302) which require the 3rd pin to remain unconnected in order to unbalance the circuit? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 21, 2011 Report Share Posted June 21, 2011 " active balanced outputs ...) which require the 3rd pin to remain unconnected in order to unbalance the circuit? " yes, which is why it is preferred to properly deal with not only the balancing/unbalancing, but also the impedance change by using a transformer or active circuit to deal with interconnect issues. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted June 21, 2011 Report Share Posted June 21, 2011 Eric, Isn't there also the scenario where you have active balanced outputs (like on the 302) which require the 3rd pin to remain unconnected in order to unbalance the circuit? By shorting pin 3 to ground you are unconnecting pin 3 from the circuit. Eric Quote Link to comment Share on other sites More sharing options...
