DPA microdot connectors
Matt Morris
Hi,
Does anyone know if it's possible to get hold of DPA microdot connectors? And if so, would it be possible to wire them to a Sanken Cos 11? I'd like to have a little flexibility with my lav mics.
I have used DPA mics, although it was a good few years ago. I seem to remember the microdot connectors being comparable to SMA connectors, i.e. just a screw in pin and screen connection. My memory could be failing me here but if that's right then how would the Sanken's three wires connect into the microdot?
I've read a little about a similar connector that Rode are now using but as far as I know they don't do a 6 pin Lemo connector, which I need to fit to my Audio Ltd tx.
Any ideas?
Hi Matt,
Convert the Sanken to a two wire configuration and then wire to the two connections in the microdot, ground and hot. Same as wiring for a Lectro SM series.
See:
http://www.lectrosonics.com/component/option,com_fss/Itemid,81/catid,4/kbartid,10/view,kb/
Use fig.5 with shield to ground-shell and bias-hot (black)to the center pin of the microdot.
Resistor (white wire source) can be anywhere from 1k to 4k with 2k being a reasonable choice.
Here's the wiring for a MM400 connector which is the same idea. Gives you an idea of the wires you will be dealing with:
http://www.lectrosonics.com/component/option,com_fss/Itemid,81/catid,4/kbartid,8/view,kb/
Best,
Larry F
Lectro
[snip]
[snip]
Any ideas?
