snd.waves Posted September 11, 2011 Report Posted September 11, 2011 Hi all, anyone know if there was a source for the lower profile female XLR connectors? Have noticed a few here and there, Loon certainly use them with their cables. I'd love to to wire some up if they're around. cheers http://www.loonaudio...=a815B4B2CC.jpg Quote
Jeff Wexler Posted September 11, 2011 Report Posted September 11, 2011 I don't know if K-Tek or Loon sells their right-angle low profile connectors on their own. Several people here, including me, have made their own by cutting up a standard XLR connector. I will do a search (ha ha) here for the pics I know have been put up on this site of the various DIY connectors people have done. Quote
ProSound Posted September 11, 2011 Report Posted September 11, 2011 Mike Clark made some nice DIY low profile connectors Quote
Peter Kurland Posted September 11, 2011 Report Posted September 11, 2011 Some of the best are the Kortwich connectors but I don't believe you can buy them as a separate part. They usually have to be attached at the dealer or factory. Professional Sound in NY has them and will make them up as needed. Quote
Jeff Wexler Posted September 11, 2011 Report Posted September 11, 2011 search (ha ha) LOL! Either I'm an idiot or the SEARCH function is just a totally useless piece of crap... probably both are true. I did multiple searches with varying filters and sorts for "XLR" and found NOTHING! This is BS. I'm going to figure out why search is so bad. In the meantime, I have found that if you do a Google search with JWSOUNDGROUP and anything else added to it, Google knows where to find these things. Quote
Jeff Wexler Posted September 11, 2011 Report Posted September 11, 2011 Google search found this link (to this site) but this site couldn't find anything! Quote
Mark Vesterskov Posted September 11, 2011 Report Posted September 11, 2011 Hi Jeff, Sorry for the offtopic, but i am a trained web developer, so i might be able to help you out. Throw me a PM if you need help. Best, Mark Quote
Jack Norflus Posted September 11, 2011 Report Posted September 11, 2011 I know k-tek sells theirs - I looked into it a while back. They are pricey and apparently a bitch to wire (so I am told - no direct experience). I ended up modifying a Neutrix XLR. Quote
snd.waves Posted September 11, 2011 Author Report Posted September 11, 2011 Thank you Jeff for the link, really interesting reading!! Will certainly be trying to make one up for myself. Quote
r.paterson Posted September 11, 2011 Report Posted September 11, 2011 hi made to measure cables but in the uk http://www.mikesfilmsound.com/new_itemM3.htm richard Quote
Jeff Wexler Posted September 11, 2011 Report Posted September 11, 2011 (the UK product) This looks to be almost identical to some of the ones I made up myself. Basically, you cut up a Neutrik connector, drill a hole in the side, find a plastic cap that fits the back --- done deal. Quote
soundtrane Posted September 11, 2011 Report Posted September 11, 2011 Jeff, main thing with the black plastic part and boot in Neutriks is between them they provide excellent strain relief. So, without both of these, an alternative method has to be found to ensure any strain on the cable does not travel right up to the solder points. Quote
Jeff Wexler Posted September 11, 2011 Report Posted September 11, 2011 Easily accomplished in the ones I did. Two ways: one is the use of epoxy --- locks everything in place, provides strain relief (but means you have to pretty much chuck the whole thing at some point in the future). Two, use a small nylon cable tie at the base of the cable as it has just passed through the hole I drilled. Quote
Geoff Tirrell Posted September 12, 2011 Report Posted September 12, 2011 I have used 2 or so layers of shrink tube as well around the end just to give a little extra protection to the wire passing through a modified metal hole and the 2nd layer on the inside only so that things can not be pulled through. Quote
soundtrane Posted September 12, 2011 Report Posted September 12, 2011 Jeff, i'd say a mini cable tie on either side of the hole... Quote
David G Posted August 6, 2012 Report Posted August 6, 2012 This is it: http://www.dpamicrophones.com/en/products.aspx?c=Item&category=144&item=24412 They work very well with the SM1500 and the 4017 or 2011C. Quote
Jeff Wexler Posted August 6, 2012 Report Posted August 6, 2012 The DPA connector looks great! I would hate to see the cost (based on what other DPA accessories cost). Also, as per the discription, it is intended for fixed installations --- hardly the same our usage, connecting, disconnecting, etc. I would worry about the ruggedness of the connector housing (what little there is of it). - from DPA: "This brilliant installation solution uses Mogami cable and an ultra slim XLR housing, adding only a few millimeters extra length to the microphone. Most of the connector will be locked and hidden in the microphone itself. For installations like concert halls, conference rooms, TV Broadcast or live sound reinforcement these cables will give the highest visual elegance. Quote
Ruben Rojas A Posted August 6, 2012 Report Posted August 6, 2012 I think Justin made a cool little mod here and it might be the one you were thinking about Jeff; this is to found in the DIY page. Anyway las post of the thread its the one I'm talking about. Quote
Vincent R. Posted August 6, 2012 Report Posted August 6, 2012 About the DPA: Yeah, The dealer here made me a special cable for a production I needed as less as weight possible on a camera. XLR/mini jack into mini jack. The connector is really light weight. I mean, really. It's plastic, all the way, I do think it's not as endurable as the one we know from neutrik, but useful for some purposes, like in a bag, on the output side. I believe there is no male version of it. Quote
bendybones Posted August 7, 2012 Report Posted August 7, 2012 The DPA connector looks great! I would hate to see the cost 90 of our Europe dollars. Yowsa! https://www.thomann.de/ie/dpa_dao_4010.htm?sid=ea840a27cac6a8bbcab5b2bc39adfa23 Quote
Vincent R. Posted August 7, 2012 Report Posted August 7, 2012 It's expensive yeah. But what you are posting is a whole assembled cable. Quote
dfisk Posted August 7, 2012 Report Posted August 7, 2012 K-Tek does sell the right angle connector that we use on the top of our Klassic poles. The list price is $25 for the connector. As someone mentioned, it is a little bit of work to solder one of these. Most low profile right angle connectors have heatshrink involved, and we have a special plastic strain relief in there to. If you haven't done one, and you look at the parts, it can be a little confusing. However, if you want us to put the connector on your pole, just send it in and we can do it. We don't charge for labor on any of our service, so you'd just pay for the connector. Some of our dealers are capable of putting on the connector as well. Quote
Marc Wielage Posted August 7, 2012 Report Posted August 7, 2012 One key to sawing a regular XLR in half: use a 3/4" plastic table leg from Lowe's hardware, and trim that to fit the XLR. This will provide a perfect cap for the connector. As the previous discussions warned, you have to fill the thing with epoxy to provide enough stability for the connector, plus strain relief for the wire itself. If these are going in a bag, make sure you know exactly what side of the connector the wire needs to stick out from. Once you figure out that angle, you can make five or six in a row and come up with a fairly workable wiring scheme. It's not quite as spiffy as the Kortwich cables (shown here), but much more affordable... Quote
studiomprd Posted August 7, 2012 Report Posted August 7, 2012 " It's plastic, all the way, " contacts ?? Quote
