soundtrane Posted September 13, 2011 Report Share Posted September 13, 2011 http://www.triall3sports.com/multipurpose.php thought this could be a good way to carry multiple boom poles... -vin Quote Link to comment Share on other sites More sharing options...
Bash Posted September 13, 2011 Report Share Posted September 13, 2011 See also various gun cases available from places like Cabelas, see http://tinyurl.com/6xmnpla Kindest regards, Simon B Quote Link to comment Share on other sites More sharing options...
Peter Deutscher Posted September 13, 2011 Report Share Posted September 13, 2011 I usually prefer something a bit lighter. Fly rod cases do the trick pretty well. http://www.cabelas.com/product/Fishing/Rod-Reel-Storage/Fishing-Rod-Tubes-Cases%7C/pc/104793480/c/104812380/sc/104541480/Cabelas-434-Diameter-Travel-Rod-Tubes/710873.uts?destination=%2Fcatalog%2Fbrowse.cmd%3FN%3D1102356%26WTz_l%3DSBC%253BBRprd710890&WTz_l=SBC%3BBRprd710890%3Bcat104541480 Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted September 13, 2011 Report Share Posted September 13, 2011 Bass Pro Shops- White River Fly Shop Rod Tubes "1000 denier Cordura® material over a tough PVC protective tube. These lightweight, airplane friendly rod tubes are outfitted with YKK zippers, and are lined with nylon for additional padding." 6 sizes, from 29" to 60" (2.5" id) ($23-25 cheap) Quote Link to comment Share on other sites More sharing options...
Geoff Tirrell Posted September 13, 2011 Report Share Posted September 13, 2011 If you want something a bit harder to store boom plus blimp and shotgun I would not count out a rifle style case from pelican If I recall they are deep enough and I have seen them used this way before. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted September 18, 2011 Report Share Posted September 18, 2011 Bass Pro Shops- White River Fly Shop Rod Tubes "1000 denier Cordura® material over a tough PVC protective tube. These lightweight, airplane friendly rod tubes are outfitted with YKK zippers, and are lined with nylon for additional padding." 6 sizes, from 28" to 60" (2.5" id) ($23-25 cheap) Update: I just received this tube for my K-Tek 100CC. Can't get a more perfect fit.. $23 (less shipping and tax) Item # 42131328 28" Rod Case. Note: The dimensions does not include the 1.25" foam inserts at each end, so the inside length is about 2" longer than stated the BassPro website Quote Link to comment Share on other sites More sharing options...
Michael McQueen Posted September 18, 2011 Report Share Posted September 18, 2011 I use one of the cabelas fly rod tubes for my 152cc, fits like a glove. Quote Link to comment Share on other sites More sharing options...
benr Posted January 26, 2012 Report Share Posted January 26, 2012 I use one of the cabelas fly rod tubes for my 152cc, fits like a glove. I have a 152CCR, which rod tube did you get and is it padded inside? Quote Link to comment Share on other sites More sharing options...
Colin Heath Posted January 26, 2012 Report Share Posted January 26, 2012 Just for storage, i bought 2 large mail tubes. had some extra foam laying around, cut and glued it to the top lid and bottom lid, then glued the bottom lid shut. For fun i added some red duct tape for a splash of color. Quote Link to comment Share on other sites More sharing options...
Derek H Posted January 26, 2012 Report Share Posted January 26, 2012 Be warned, I have a Cabelas fly rod tube case that I've been using for a few years (light use) and recently the bottom cap popped out and the pole fell. Not designed to hold the weight of the pole obviously. Something to watch out for. Quote Link to comment Share on other sites More sharing options...
benr Posted January 26, 2012 Report Share Posted January 26, 2012 Yea Ill probably be doing something along the lines of making my own like the Alfa cases. Its easy and cheaper than buying any of the "pre-built" or made for something else products I have seen so far. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted January 27, 2012 Report Share Posted January 27, 2012 For cart gigs I carry two or three dressed booms mounted on the cart, but for smaller jobs here's what I use. It holds both a 13' K-Tek Pole with a 416 in full Rycote windscreen and Windjammer, and an 8' vDB pole with Schoeps installed. Both mics are dressed, mounted, and ready for action. I have foam inserts that hold the longer pole in position and I pop some foam pipe insulation around the vDB to keep it from rubbing against the other boom. Works great and when someone asks me why I'm carrying a gun onto the set, I just smile and say, "Nobody gives me any flack." http://tinyurl.com/7tz9mal And at $34 it's a great bargain. Quote Link to comment Share on other sites More sharing options...
benr Posted January 27, 2012 Report Share Posted January 27, 2012 For cart gigs I carry two or three dressed booms mounted on the cart, but for smaller jobs here's what I use. It holds both a 13' K-Tek Pole with a 416 in full Rycote windscreen and Windjammer, and an 8' vDB pole with Schoeps installed. Both mics are dressed, mounted, and ready for action. I have foam inserts that hold the longer pole in position and I pop some foam pipe insulation around the vDB to keep it from rubbing against the other boom. Works great and when someone asks me why I'm carrying a gun onto the set, I just smile and say, "Nobody gives me any flack." http://tinyurl.com/7tz9mal And at $34 it's a great bargain. Whoa! Now that option I like! I intend to carry in it exactly what you are. Perfect. I'll be ordering one of those up! Quote Link to comment Share on other sites More sharing options...
Jan McL Posted January 27, 2012 Report Share Posted January 27, 2012 For cart gigs I carry two or three dressed booms mounted on the cart, but for smaller jobs here's what I use. It holds both a 13' K-Tek Pole with a 416 in full Rycote windscreen and Windjammer, and an 8' vDB pole with Schoeps installed. Both mics are dressed, mounted, and ready for action. I have foam inserts that hold the longer pole in position and I pop some foam pipe insulation around the vDB to keep it from rubbing against the other boom. Works great and when someone asks me why I'm carrying a gun onto the set, I just smile and say, "Nobody gives me any flack." http://tinyurl.com/7tz9mal And at $34 it's a great bargain. "Nobody gives me any flack." That's a keeper, as is the repurposed case, Mr. Blankenship. I'm not certain I have what it takes to pull that off, but I'm gonna meditate on it over the weekend and see where that gets me. -- Jan Quote Link to comment Share on other sites More sharing options...
benr Posted January 27, 2012 Report Share Posted January 27, 2012 For $34 how can you go wrong?! Quote Link to comment Share on other sites More sharing options...
jhaudio Posted January 27, 2012 Report Share Posted January 27, 2012 I purchased an Alfa Case BoomTube which is about $90 bucks IIRC. Depends on your boom pole size. Not a cheap option.... but is a hard case that takes up little real estate http://www.alfacase.com/Boom_Tube.html Quote Link to comment Share on other sites More sharing options...
benr Posted January 27, 2012 Report Share Posted January 27, 2012 I purchased an Alfa Case BoomTube which is about $90 bucks IIRC. Depends on your boom pole size. Not a cheap option.... but is a hard case that takes up little real estate http://www.alfacase.com/Boom_Tube.html Yea I had seen those first and after realizing they are just like what you can build yourself I decided to go that route. Quote Link to comment Share on other sites More sharing options...
saadasound Posted January 28, 2012 Report Share Posted January 28, 2012 I made a PVC tube. 3 inch PVC. Go to a tackle shop or Bass Pro shop and get the PVC lids for fishing Rods. Pretty much a sealed cover on Bottom and a water proof top lid that snaps open with a lock hole as well. You can put a strap through the strap slits as well. Works great, lightweight, safe, perfect. Oh and most important... It only costs about 25 dollars Quote Link to comment Share on other sites More sharing options...
DanieldH Posted January 28, 2012 Report Share Posted January 28, 2012 Me and quite a few rental places here in Germany use polypropylene pipe commonly used for wastewater in buildings. They fit Ambient poles perfectly, the pole foot fits in the sleeve and any hardware store provides lids and washers, sealing the boom quite water and airtight. Costs under 5 Euro. Quote Link to comment Share on other sites More sharing options...
benr Posted February 4, 2012 Report Share Posted February 4, 2012 Well, got the rifle case today and its going work, but it is too small to fit a Rycote Full windshield Kit 4 attached to a K-Tek K-152CCR boom pole attached together. If I didnt have the right angle base on it it would have been a perfect fit. Needs a lot more padded for my perference, but a quick trip to my local craft store will fix that. For now I placed it in the case so you all can see how it fits. Fits great once the WindShield is removed from the pole and laid on top. Again, this is the rifle case from amazon: http://www.amazon.com/gp/product/B000P3WPXM/ref=oh_o03_s00_i00_details Quote Link to comment Share on other sites More sharing options...
Jack Pender Posted February 4, 2012 Report Share Posted February 4, 2012 I have a home made PVC case that works great, very cheap. I will be making another one for my other booms soon. Quote Link to comment Share on other sites More sharing options...
