Michael Miramontes Posted October 22, 2012 Report Share Posted October 22, 2012 It is coming along with automix? I still wish there was a way to monitor the gain setting on my TRX's from my Nomad or QRX100. I was listening to one of my TRX tracks and noticed it was a bit hot compared to my Nomad tracks. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted October 22, 2012 Report Share Posted October 22, 2012 This is the kind of stuff that Total mix is just awesome at. yes. philp Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 22, 2012 Report Share Posted October 22, 2012 along with automix? I still wish there was a way to monitor the gain setting on my TRX's from my Nomad or QRX100. I was listening to one of my TRX tracks and noticed it was a bit hot compared to my Nomad tracks. I think it was established to be impossible. If you use zax gain and AES it should be pretty close. What I don't like in this case is the channel knob becomes gain instead of autogain menu button. Quote Link to comment Share on other sites More sharing options...
galwaysound Posted October 22, 2012 Report Share Posted October 22, 2012 I still wish there was a way to monitor the gain setting on my TRX's from my Nomad or QRX100. I've been able to monitor Trx gain from my Qrx 100. Not at my kit at the moment but if I remember correctly I set IFB to on. In the pacifier page cycle through the screens and you'll come to gain page and you can jump between Trxs by pressing A/B. I'm sure Jack or someone more familiar will jump in and verify correct set up. I can double check when I get home and repost. Regards Trev Quote Link to comment Share on other sites More sharing options...
Mark Orusa Posted October 23, 2012 Report Share Posted October 23, 2012 I still wish there was a way to monitor the gain setting on my TRX's from my Nomad or QRX100. I was listening to one of my TRX tracks and noticed it was a bit hot compared to my Nomad tracks. I think the closest you can get is to assign one of the Nomad's faders to the TRX gain. Since the Nomad knobs have finite range they essentially show you the level of the transmitter. You should be able to figure out what the gain is at 12 o'clock, 3 o'clock, etc. Mark O. Quote Link to comment Share on other sites More sharing options...
OscarL Posted October 23, 2012 Report Share Posted October 23, 2012 Definitely not -20C, but I took my Fusion (not Nomad, but still) in some cold and it didn't blink. It was cold enough that the Red we were shooting on froze up and had to be revived with a propane heater. We even tried it with an AC adapter and a geni, and nothing till we warmed it up for a good 30 minutes. I haven't tried the Nomad either, but my DevaV has been working without any problems in -38C for three days straight, with the internal hd and an NP1 lasting between 5-6 hours, even the display worked good. Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted October 23, 2012 Report Share Posted October 23, 2012 I think the closest you can get is to assign one of the Nomad's faders to the TRX gain. Since the Nomad knobs have finite range they essentially show you the level of the transmitter. You should be able to figure out what the gain is at 12 o'clock, 3 o'clock, etc. Mark O. hmm, now that's something to think about. thanks Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted October 23, 2012 Report Share Posted October 23, 2012 I haven't tried the Nomad either, but my DevaV has been working without any problems in -38C for three days straight, with the internal hd and an NP1 lasting between 5-6 hours, even the display worked good. The touchscreen display at that. I was worried I would lose the ability to enter metadata, but it worked 100%. I can only guess it was the image sensor on the Red camera that crapped out. I was only in PA, and while it was cold, it wasn't like I was retracing Shackleton's journey in Antarctica. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted October 23, 2012 Report Share Posted October 23, 2012 hmm, now that's something to think about. thanks It works great! Quote Link to comment Share on other sites More sharing options...
galwaysound Posted October 23, 2012 Report Share Posted October 23, 2012 Regarding monitoring TRX gain from Qrx From Qrx notes firmware 2.11 "added support for displaying TRX's current gain setting in the TX GAIN remote screen (requires TRX-770 or higher)" I stated in a previous post that I thought it was 'IFB on', I was incorrect on this, it is 'TX GAIN' on. It's then possible to monitor TRX gain from Qrx screen, if gain is adjusted on TRX or Nomad it changes on Qrx screen. Regarding adjusting gain via Nomad fader; 12 o'clock equates to 27dB, 3o'clock to 44dB(approximately) Trevor McKenna Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 25, 2012 Author Report Share Posted October 25, 2012 Software version 4.0 has just been posted on the Zaxcom forum in the files and download section. Quote Link to comment Share on other sites More sharing options...
mastermixaudiomedia Posted October 25, 2012 Report Share Posted October 25, 2012 Was just getting ready to leave work after playing with Nomad all day, guess I'll be here a little longer... :-) Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 25, 2012 Author Report Share Posted October 25, 2012 Was just getting ready to leave work after playing with Nomad all day, guess I'll be here a little longer... :-) it will be worth it Quote Link to comment Share on other sites More sharing options...
mastermixaudiomedia Posted October 25, 2012 Report Share Posted October 25, 2012 it will be worth it Looks good so far... will run it through the paces tomorrow Quote Link to comment Share on other sites More sharing options...
James Arnold Posted October 26, 2012 Report Share Posted October 26, 2012 Loving the changes so far! The virtual fader control and the new record enable indications are excellent! Also loving the fact that screen brightness now goes up to ELEVEN - hahaha! I presume MP3 will be operational with USB functionality? Transcription ability would be a BIG bonus! Cannot wait for Auto Mix... Quote Link to comment Share on other sites More sharing options...
Matt Martin Posted October 26, 2012 Report Share Posted October 26, 2012 Haha they really put the number 11 as the max? love it. I'll be downloading it tonight. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 26, 2012 Author Report Share Posted October 26, 2012 Haha they really put the number 11 as the max? love it. Yep because it is 1 brighter than 10 . . . isn't it? Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted October 26, 2012 Report Share Posted October 26, 2012 It would have been way cool if Howy made the screen mod go to eleven. For when you need that extra push over the cliff. They probably debated it and it probably went like this: Glenn Sanders: Oh, I see. And most screens go up to ten? Howy: Exactly. Glenn Sanders: Does that mean it’s brighter? Is it any brighter? Howy: Well, it’s one brighter, isn’t it? It’s not ten. You see, most blokes, you know, will be mixing at ten. You’re on ten here, all the way up, all the way up, all the way up, you’re on ten on your screen. Where can you go from there? Where? Glenn Sanders: I don’t know. Howy: Nowhere. Exactly. What we do is, if we need that extra push over the cliff, you know what we do? Glenn Sanders: Put it up to eleven. Howy: Eleven. Exactly. One brighter. Glenn Sanders: Why don’t you just make ten brighter and make ten be the top number and make that a little brighter? Howy: [pause, chewing gum] These go to eleven. Quoting myself (weird) Howy! Glenn! Did my late night ramblings influence the screen mod brightness now going to eleven? I'm cracking up! Please pm me or confirm my that my joking around may have influenced this 4.0 revision so I can earnestly tell the tale to colleagues without a doubt of my possible telling a tall tale. TOO FUNNY! Nomad goes to eleven! There's a new t-shirt! Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted October 26, 2012 Report Share Posted October 26, 2012 Regarding monitoring TRX gain from Qrx From Qrx notes firmware 2.11 "added support for displaying TRX's current gain setting in the TX GAIN remote screen (requires TRX-770 or higher)" I stated in a previous post that I thought it was 'IFB on', I was incorrect on this, it is 'TX GAIN' on. It's then possible to monitor TRX gain from Qrx screen, if gain is adjusted on TRX or Nomad it changes on Qrx screen. Regarding adjusting gain via Nomad fader; 12 o'clock equates to 27dB, 3o'clock to 44dB(approximately) Trevor McKenna That's interesting. I wasn't able to find the tx gain screen earlier, I'll check tomorrow and see if I have the option turned off. Honestly I still set the gains by the meters, so associating a number to it doesn't mean much to me, but still interesting. Wandering Ear Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 26, 2012 Report Share Posted October 26, 2012 Software version 4.0 has just been posted on the Zaxcom forum in the files and download section. It is more exciting then the release of windows 8. Thank you ZAX. Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted October 26, 2012 Report Share Posted October 26, 2012 Or the 11 brightness is a secret tribute to Spinal Tap? -- J1mbo, whatever happened to you??? If Zaxcom made you happy, what is there that they can't do? Quote Link to comment Share on other sites More sharing options...
glenn Posted October 27, 2012 Report Share Posted October 27, 2012 Quoting myself (weird) Howy! Glenn! Did my late night ramblings influence the screen mod brightness now going to eleven? I'm cracking up! Please pm me or confirm my that my joking around may have influenced this 4.0 revision so I can earnestly tell the tale to colleagues without a doubt of my possible telling a tall tale. TOO FUNNY! Nomad goes to eleven! There's a new t-shirt! I thought if it went to 11 it would be an easy way to know that the software was the new revision. And yes, I thought it was funny. I asked Howy to put it in. Thanks for the suggestion. Glenn Quote Link to comment Share on other sites More sharing options...
Srgtfury Posted October 27, 2012 Report Share Posted October 27, 2012 Everyone's a comedian... Btw anxious for automix, which is supposed to be in Beta now. Is that only available for select Beta testers? if so, is there a wider release, before officially released? Thank you very much Fury Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted October 27, 2012 Report Share Posted October 27, 2012 Everyone's a comedian... Btw anxious for automix, which is supposed to be in Beta now. Is that only available for select Beta testers? if so, is there a wider release, before officially released? Thank you very much Fury In beta means it's for beta testers only and not publically released. Otherwise it wouldn't be beta. Wandering Ear Quote Link to comment Share on other sites More sharing options...
Srgtfury Posted October 27, 2012 Report Share Posted October 27, 2012 In beta means it's for beta testers only and not publically released. Otherwise it wouldn't be beta. Wandering Ear Ho Wanda, Are U responding for Zaxcom? Hmmm...Certainly there have been many companies that have allowed end users to download, what they have referred to as, "Beta" software, prior to an official release. Some allow official releases of software that should have been restricted to select beta testers...or never released. These scenarios have played out many times, since the last millennium. Fury notes that it is short sighted to indicate, however, that, as generically axiomatic, a public availability of software, would preclude Beta status. That pretty much covers it, from alpha to... Efharisto very much Fury Quote Link to comment Share on other sites More sharing options...
