BHSound Posted January 30, 2013 Report Share Posted January 30, 2013 I am having phantom power poping problems with my nomad. Is this a software issue or a hardware issue? The poping is very intermittent and extremely bothersome. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted January 30, 2013 Author Report Share Posted January 30, 2013 It could be a bad capacitor. Quote Link to comment Share on other sites More sharing options...
ramallo Posted January 30, 2013 Report Share Posted January 30, 2013 I am having phantom power poping problems with my nomad. Is this a software issue or a hardware issue? The poping is very intermittent and extremely bothersome. Any suggestions? Is a very common failure (on early Nomads), I had a unit with a strong pops on several inputs (with and without phantom), now I have a new one with some noise in two inputs ( still waiting for a new input board) Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted February 21, 2013 Report Share Posted February 21, 2013 Alright, what's the easiest way to mix channels 7/8? The virtual fader screen just isn't quick enough. Quote Link to comment Share on other sites More sharing options...
Max Hirtenstein Posted February 21, 2013 Report Share Posted February 21, 2013 Alright, what's the easiest way to mix channels 7/8? The virtual fader screen just isn't quick enough. Mix pre sending AES? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted February 21, 2013 Author Report Share Posted February 21, 2013 Alright, what's the easiest way to mix channels 7/8? The virtual fader screen just isn't quick enough.vf mode. Its available on your eng pan screen. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted February 21, 2013 Report Share Posted February 21, 2013 " i 'm shure i had the correct cable for this purpose..the SB-T and the cable are from a very serious rental compagny..." so? they could be supplying a cable that works with other gear..." I first thought the cable was faulty, so i tried 3 or 4 other cables. " where were these from ? theycould have been the same incorrect wiring... did you try the test suggested... " i Just don't like not understanding why.. " It could be the cable, or it could be the box... Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted February 21, 2013 Report Share Posted February 21, 2013 vf mode. Its available on your eng pan screen. Yes, but having to toggle between each fader isn't really working out for me. I need something quicker then that. Mix pre sending AES? I had seen your post before on this. How is this working out for you? Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted February 21, 2013 Report Share Posted February 21, 2013 I agree with you Michael, vf isn't an enjoyable mixing experience for me either. Hoping for an external fader module in the future. And panning... Uhg. Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted February 21, 2013 Report Share Posted February 21, 2013 I agree with you Michael, vf isn't an enjoyable mixing experience for me either. Hoping for an external fader module in the future. And panning... Uhg. Before I posted my question I had checked the site first for any suggestions. I stumbled across a a post in which Glenn said there are no plans for an external fader module. =( Quote Link to comment Share on other sites More sharing options...
PTA Posted February 21, 2013 Report Share Posted February 21, 2013 Before I posted my question I had checked the site first for any suggestions. I stumbled across a a post in which Glenn said there are no plans for an external fader module. =( What about 2 Emergency Rx's? That's what I'd try. Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted February 21, 2013 Report Share Posted February 21, 2013 What about 2 Emergency Rx's? That's what I'd try. I've never seen those. Looks pretty slick. Thanks for the suggestion. Quote Link to comment Share on other sites More sharing options...
PTA Posted February 21, 2013 Report Share Posted February 21, 2013 I've never seen those. Looks pretty slick. Thanks for the suggestion. No problem. That's the easiest way I could think of that gives you a physical fader. I haven't actually test it out yet though. I could today to see if it works if you'd like. Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted February 21, 2013 Report Share Posted February 21, 2013 No problem. That's the easiest way I could think of that gives you a physical fader. I haven't actually test it out yet though. I could today to see if it works if you'd like. Yes, please. I would appreciate that. Thanks Quote Link to comment Share on other sites More sharing options...
PTA Posted February 21, 2013 Report Share Posted February 21, 2013 Yes, please. I would appreciate that. Thanks Works good on my end. Quote Link to comment Share on other sites More sharing options...
Max Hirtenstein Posted February 21, 2013 Report Share Posted February 21, 2013 Yes, but having to toggle between each fader isn't really working out for me. I need something quicker then that. I had seen your post before on this. How is this working out for you? Hmm wasn't me. It is in the to do list as I want a mix pre anyway as a backup mixer. Also, funny story- I was in a dub stage with mark yesterday when you sent someone over to pick up something for anodizing small world. Quote Link to comment Share on other sites More sharing options...
glenn Posted February 21, 2013 Report Share Posted February 21, 2013 Fader control can be easily accessed directly from the ENG home screen. Nomad can be setup to directly access channels 7 and 8 only. Pressing the menu encoder will toggle between the 2 channels. The virtual fader screen is not necessary at this point. Glenn Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted February 22, 2013 Report Share Posted February 22, 2013 Fader control can be easily accessed directly from the ENG home screen. Nomad can be setup to directly access channels 7 and 8 only. Pressing the menu encoder will toggle between the 2 channels. The virtual fader screen is not necessary at this point. Glenn Thanks. I'll give it a try. Quote Link to comment Share on other sites More sharing options...
TallgrassPictures Posted February 25, 2013 Report Share Posted February 25, 2013 Hi Everyone, I was wondering if there is an experienced (15+ years ) Location Mixer who is familiar with a Zaxcom Nomad config who can do a 1-day training session for common location sound practices. I'm new to the production sound industry and would like someone in the LA,OC,SD (California) area to show me the ropes using a Nomad. If you are interested please email me with your name, years of experience, available equipment, rate(for half day or full day) and contact info: yoshi@tallgrasspictures.com Thanks, Yoshi Quote Link to comment Share on other sites More sharing options...
Chris Woodcock Posted February 25, 2013 Report Share Posted February 25, 2013 Hi Everyone, I was wondering if there is an experienced (15+ years ) Location Mixer who is familiar with a Zaxcom Nomad config who can do a 1-day training session for common location sound practices. I'm new to the production sound industry and would like someone in the LA,OC,SD (California) area to show me the ropes using a Nomad. If you are interested please email me with your name, years of experience, available equipment, rate(for half day or full day) and contact info: yoshi@tallgrasspictures.com Thanks, Yoshi Why do you think someone who has 15 years experience knows more about a machine that's less than 2 years old? Regards Chris W Quote Link to comment Share on other sites More sharing options...
Max Futterman Posted February 25, 2013 Report Share Posted February 25, 2013 Yoshi, I'd contact your local dealer about getting a demo. It's been my experience that most are happy to oblige. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted February 25, 2013 Author Report Share Posted February 25, 2013 Zaxcom also has some excellent nomad demo videos: http://m.youtube.com/#/zaxcom1?uid=3YWnsszJRAo7RRcXUhkWQA&desktop_uri=%2Fzaxcom1 Quote Link to comment Share on other sites More sharing options...
Eric Lawrence Posted February 28, 2013 Report Share Posted February 28, 2013 Is it possible to remirror a folder that was originally recorded as mono wave files as poly wave files? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted February 28, 2013 Author Report Share Posted February 28, 2013 Is it possible to remirror a folder that was originally recorded as mono wave files as poly wave files? yes Just change the settings in the mirror menu and you are good to go. Quote Link to comment Share on other sites More sharing options...
Eric Lawrence Posted February 28, 2013 Report Share Posted February 28, 2013 Thanks Jack, that's a relief. Can the proceas be explained in a response, or is it fairly complicated? Quote Link to comment Share on other sites More sharing options...
