Jack Norflus Posted April 3, 2014 Author Report Share Posted April 3, 2014 It is possible and Howy was working on it but it was causing other issues with other functions. And was takeing a lot of time to resolve - so it was put on the back burner for now so he can work on some other petty cool functionality for both nomad and maxx. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 4, 2014 Author Report Share Posted April 4, 2014 As far a the fader panel it is a small panel the gets mounted to the top of nomad. It has 8 rotary faders and the software allows each fader to be assigned to be used as a fader - control trim or adjust Zaxnet gain. Each fader can be assigned any function in any combination. There are 8 dedicated pfl keys and a dedicated record key. As well an another star key for additional future functionality. FYI the new software for the fader panel gives the mix 8 additional functionality. Quote Link to comment Share on other sites More sharing options...
bendybones Posted April 4, 2014 Report Share Posted April 4, 2014 Looking forward to seeing that fader panel. Even more looking forward to Fader Assign extending to all inputs. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted April 4, 2014 Report Share Posted April 4, 2014 I use extension fader for my MIX-8 Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted April 4, 2014 Report Share Posted April 4, 2014 What is the expected price point on the fader panel? Quote Link to comment Share on other sites More sharing options...
pindrop Posted April 4, 2014 Report Share Posted April 4, 2014 As far a the fader panel it is a small panel the gets mounted to the top of nomad. It has 8 rotary faders and the software allows each fader to be assigned to be used as a fader - control trim or adjust Zaxnet gain. Each fader can be assigned any function in any combination. There are 8 dedicated pfl keys and a dedicated record key. As well an another star key for additional future functionality. FYI the new software for the fader panel gives the mix 8 additional functionality. This sounds great, do you happen to know whether the additional star key you mention can be assigned to replace the star key on the main Nomad panel (between back and menu) as I've always found this position to not be as accessible as I'd like? thanks Quote Link to comment Share on other sites More sharing options...
bendybones Posted April 4, 2014 Report Share Posted April 4, 2014 Rado you're using it? Any photos? Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted April 7, 2014 Report Share Posted April 7, 2014 I installed 6.32 and now my Mix 8 doesnt work anymore. Zax is at NAB. Helpful advice anyone maybe? Quote Link to comment Share on other sites More sharing options...
rich Posted April 7, 2014 Report Share Posted April 7, 2014 I installed 6.32 and now my Mix 8 doesnt work anymore. Zax is at NAB. Helpful advice anyone maybe? probably not the kind of helpful you are looking for, but go back to the latest firmware that allowed the mix 8 to work properly - assuming that in the upgrade a menu setting hasnt changed. and a factory reset doesnt work either. Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted April 7, 2014 Report Share Posted April 7, 2014 Already rolled back to 6.22. wondering if others' Mix8 stopped working on 6.32 too. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted April 7, 2014 Report Share Posted April 7, 2014 6.32 works with mix-8. There is a new and better way to assign faders. Go to the external faders menu. It is a new menu above fader assign. You can assign any channel to any fader. Great for people using AES 3/4 5/6 7/8 where 7/8 is your 1/2. Also I just told Glenn to tell howy to make Fader assign presets. On my cart I use nomad knobs for zaxnet gain and when I jump off my cart I have to reassign them to normal gain stage control one by one. Fader assign presets will be great... Quote Link to comment Share on other sites More sharing options...
dominiquegreffard Posted April 7, 2014 Report Share Posted April 7, 2014 Quote Link to comment Share on other sites More sharing options...
cameronlenart Posted April 7, 2014 Report Share Posted April 7, 2014 Is auto pan working with digital inputs on latest firmware? Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted April 7, 2014 Report Share Posted April 7, 2014 What is the price point on the extension panel? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted April 8, 2014 Report Share Posted April 8, 2014 What is the price point on the extension panel? $895 Quote Link to comment Share on other sites More sharing options...
Ben Posted April 9, 2014 Report Share Posted April 9, 2014 2 quick questions. 1 - I just upgraded my Lite to a 10 (What took me so long? rhetorical) and now I can no longer record out 5 or 6 whereas I could on the Lite. Is that true? Am I missing something in the Bus matrix? What is up with that? 2 - Prior to upgrading to 10 I installed new firmware, 6.22 to be exact, which includes a new Bootloader, V17. I burned the new bootloader but then I saw a post by Jack that says this was for a change in the parts on newer models. Mine is from 1.5 years ago. Did I do a bad thing? I have scoured the Zaxcom forum with no success. Bonus third question for extra credit - I was under the impression that updating the bootloader was a good thing. Perhaps no? Quote Link to comment Share on other sites More sharing options...
Marc Hoppe Posted April 9, 2014 Report Share Posted April 9, 2014 Ben, I'm not 100% certain, but I think that you can't record out 5/6 because there are 10 tracks: inputs 1-6, return 1/2 and return 3/4. Check the bus routing menu. No clue about the Bootloader. Marc Quote Link to comment Share on other sites More sharing options...
rich Posted April 9, 2014 Report Share Posted April 9, 2014 i only ever remember being able to select output 1-4 to record, so that may well be a difference between in the firmware for the 2 machines. i have a nomad 12. but will switch my machine on shortly to double check. I'm curious though, are you needing to record all 6 outputs that you need this? or how are you set up? has burning the new bootloader affected anything? would hope that it will work fine with older revision hardware with no ill effect. Quote Link to comment Share on other sites More sharing options...
Ben Posted April 9, 2014 Report Share Posted April 9, 2014 Thanks for the quick response Marc and Rich. Let me lay out a quick scenario. 1 Boom and 4 wires. Boom on Output 1 or 3 - Armed for recording. Lavs recorded on iso 2-5. Out on 2 and/or 4 Sometimes I need to send 2 stereo mixes So I put the Auto Mix on Out 6, just to keep it out the way and send it to ERXs. Suppose I want to arm Out 6 for recording. That would only be 6 tracks recorded max. I am curious because the Matrix is lined up for Vertically for Card Tracks and Horizontally for Busses. Just curious why I can record literally everything else, even Slate and Com, but not 5/6. Is this option available on the 12. Why was it an option on the Lite? That is all. Just curious, not complaining. The Nomad is one hell of a machine. Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted April 9, 2014 Report Share Posted April 9, 2014 I can't find an answer in the manual. Can I use the same TA5 and XLR outputs simultaneously? Quote Link to comment Share on other sites More sharing options...
rich Posted April 9, 2014 Report Share Posted April 9, 2014 I can't find an answer in the manual. Can I use the same TA5 and XLR outputs simultaneously? yes Quote Link to comment Share on other sites More sharing options...
Nate C Posted April 9, 2014 Report Share Posted April 9, 2014 ^^^Yes you can. I use xlr 1 and 2 out for my wireless link and TA5 out 1/2 for return cable often. Edit. Rich is a much quicker typer than me. Quote Link to comment Share on other sites More sharing options...
rich Posted April 9, 2014 Report Share Posted April 9, 2014 ^^^Yes you can. I use xlr 1 and 2 out for my wireless link and TA5 out 1/2 for return cable often. Edit. Rich is a much quicker typer than me. nah. just less letters to type. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 10, 2014 Author Report Share Posted April 10, 2014 2 quick questions. 1 - I just upgraded my Lite to a 10 (What took me so long? rhetorical) and now I can no longer record out 5 or 6 whereas I could on the Lite. Is that true? Am I missing something in the Bus matrix? What is up with that? 2 - Prior to upgrading to 10 I installed new firmware, 6.22 to be exact, which includes a new Bootloader, V17. I burned the new bootloader but then I saw a post by Jack that says this was for a change in the parts on newer models. Mine is from 1.5 years ago. Did I do a bad thing? I have scoured the Zaxcom forum with no success. Bonus third question for extra credit - I was under the impression that updating the bootloader was a good thing. Perhaps no? You can record 5 and 6 - don't have a machine with me to see how exactally - if I get a moment at show later I will post. No worries about the boot loader - you are not going to do any damage. Bonus - it depends. If it was necessary Howy will tell us it is necessary. But it is unlikely that current machines will ever have to update the bootloader Quote Link to comment Share on other sites More sharing options...
studiomprd Posted April 12, 2014 Report Share Posted April 12, 2014 Lancashire: " Can I use the same TA5 and XLR outputs simultaneously? " what happens when you try ? Quote Link to comment Share on other sites More sharing options...
