Wandering Ear Posted April 12, 2014 Report Share Posted April 12, 2014 Jack, I've never seen a way to record out 5 or 6 on my nomad 12. I just double checked, and there is no routing option. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 12, 2014 Author Report Share Posted April 12, 2014 Jack, I've never seen a way to record out 5 or 6 on my nomad 12. I just double checked, and there is no routing option. You are correct. I apologize for mis-posting. That is what happens when one has too many cocktails in Vegas and then goes to jw sound. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted April 12, 2014 Report Share Posted April 12, 2014 You are correct. I apologize for mis-posting. That is what happens when one has too many cocktails in Vegas and then goes to jw sound. Drunk posting Quote Link to comment Share on other sites More sharing options...
bassmagnetic Posted May 11, 2014 Report Share Posted May 11, 2014 searched but can't find an answer... Is it possible to assign the vfaders? or do they only apply to the analog return inputs? If they are virtual faders surely we should be able to assign from the 'fader assign' page? I'm using a mixture of 6 AES inputs and 2 analog... at the moment it looks like the only way I could potentially mix the 8 inputs utilising vfader is to make a TA5 cable to go into the returns.... does anyone know of any other way? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 11, 2014 Author Report Share Posted May 11, 2014 You can assign inputs 1-8 to any hardware fader. So any one of your 6 AES inputs or your 2 analog inputs (provided that they are coming in on inputs 7 and can be assigned to any hardware fader. Quote Link to comment Share on other sites More sharing options...
bassmagnetic Posted May 11, 2014 Report Share Posted May 11, 2014 so vfaders are 'hardwired' to analog inputs returns 7/8 and 9/10... I can only assign inputs to the 6 fader knobs? Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted May 11, 2014 Report Share Posted May 11, 2014 so vfaders are 'hardwired' to analog inputs returns 7/8 and 9/10... I can only assign inputs to the 6 fader knobs? Correct. Quote Link to comment Share on other sites More sharing options...
bassmagnetic Posted May 11, 2014 Report Share Posted May 11, 2014 thanks both.... soldering iron in hand.... Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted May 11, 2014 Report Share Posted May 11, 2014 yes Sorry, I forgot to thank you for the useful reply. Quote Link to comment Share on other sites More sharing options...
Derek H Posted May 11, 2014 Report Share Posted May 11, 2014 I think Nomad and Maxx should have a v-fader assign page similar to the regular fader assign. Quote Link to comment Share on other sites More sharing options...
zerascal Posted May 12, 2014 Report Share Posted May 12, 2014 +1 Quote Link to comment Share on other sites More sharing options...
dominiquegreffard Posted May 20, 2014 Report Share Posted May 20, 2014 Two more requests: - some kind of shortcut to ajdust screen brightness faster. - a display of the zaxnet ifb mode on the card page ( tx, rx or tx/rx ). Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted June 11, 2014 Report Share Posted June 11, 2014 Most used: Change track names Change primary folder Change folder name Screen brightness Would be great to get to these quickly-er Quote Link to comment Share on other sites More sharing options...
dominiquegreffard Posted June 11, 2014 Report Share Posted June 11, 2014 Most used: Change track names Change primary folder Change folder name Screen brightness Would be great if I could get to these quickly-er Yeah especially the screen brightness. it s very deep in the menu. I suggest a hold bus button and turn menu combo to adjust on the fly. Zax do have A LOT on their plate right now. Quote Link to comment Share on other sites More sharing options...
Derek H Posted June 11, 2014 Report Share Posted June 11, 2014 These things are buried a bit but I will say that it's nice that the menu system remembers what item you last adjusted. Makes it a little quicker to get back and adjust, say, the LCD brightness when going from outside to inside and back again. Once you get used to the interface everything is pretty quick. The less button combo shortcuts I have to remember the better I say. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 11, 2014 Report Share Posted June 11, 2014 These things are buried a bit but I will say that it's nice that the menu system remembers what item you last adjusted. Makes it a little quicker to get back and adjust, say, the LCD brightness when going from outside to inside and back again. Once you get used to the interface everything is pretty quick. The less button combo shortcuts I have to remember the better I say. +1 Quote Link to comment Share on other sites More sharing options...
VASI Posted September 30, 2014 Report Share Posted September 30, 2014 From Kortwich: VCP-M4 for Zaxcom Nomad Input Panel: 4x Mic input Hirose DC IN und OUTFront Panel: 4x Channel fader 4x PH 48V ON/OFFOutput Panel: 4x OUT (Nomad) Power LED ON/OFF -- My German level of language does not help me to find more information about this product. It's additional mic preamps and line output for full 10 mic preamps as I understand. 690€ Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted September 30, 2014 Report Share Posted September 30, 2014 Cool to see other accessories being developed by other manufacturers. Thanks for sharing Vasileios. If I'm understanding this VCP-M4 unit correctly, I see some potential design flaws with it though: - Outputs should be on the right side, not the left side, so that you can patch into the Returns of the Nomad which are on the right side. - DC In and out should be on the left side, not the right side, so that you daisy chain power into the Nomad which has its hirose 4-pin on the left side. - While the TA5F make sense for the outputs, as you can easily do TA5F to TA5F cables to go from this unit to the Returns on the Nomad, the TA3F for mic inputs does not make sense to me. Anyhow, just some thoughts. Quote Link to comment Share on other sites More sharing options...
VASI Posted September 30, 2014 Report Share Posted September 30, 2014 Hi Jose, I think the TA5F are for inputs. Maybe someone from Germany or with a good German language level skills can help. Quote Link to comment Share on other sites More sharing options...
Constantin Posted October 2, 2014 Report Share Posted October 2, 2014 Indeed the TA5's appear to be for the inputs and are on the left side. Outputs are on TA3 and are on the left. No German required, just look here: http://www.filmtontechnik.de/613.html Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 2, 2014 Report Share Posted October 2, 2014 From Kortwich: VCP-M4 for Zaxcom Nomad Input Panel: 4x Mic input Hirose DC IN und OUT Front Panel: 4x Channel fader 4x PH 48V ON/OFF Output Panel: 4x OUT (Nomad) Power LED ON/OFF -- My German level of language does not help me to find more information about this product. It's additional mic preamps and line output for full 10 mic preamps as I understand. 690€ For this special times when you need 10 booms in a scene... Quote Link to comment Share on other sites More sharing options...
VASI Posted October 2, 2014 Report Share Posted October 2, 2014 Or for complex effects recordings. Quote Link to comment Share on other sites More sharing options...
zerascal Posted October 2, 2014 Report Share Posted October 2, 2014 Indeed the TA5's appear to be for the inputs and are on the left side. Outputs are on TA3 and are on the left. No German required, just look here: http://www.filmtontechnik.de/613.html I'd say TA5 are for outputs (logic integration with nomad Ta5 line input) and TA3 for the inputs. Quote Link to comment Share on other sites More sharing options...
Constantin Posted October 2, 2014 Report Share Posted October 2, 2014 I'd say TA5 are for outputs (logic integration with nomad Ta5 line input) and TA3 for the inputs.OK. I think if you follow the link and look at the picture, it doesn't seem to corroborate your statement, but the labels may be weird, so I don't know for sure. And actually, I don't care. Someone send Kortwich an email? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 2, 2014 Report Share Posted October 2, 2014 constantin: " Someone send Kortwich an email? " I guess if you want to know, you could... Quote Link to comment Share on other sites More sharing options...
