Audio Daddyo Posted November 30, 2011 Report Share Posted November 30, 2011 A friend wants me to repair his cable that goes from his G2 Rx to his mixer. It's a locking TRS mini to XLR male. Does anyone know the proper wiring for this cable. Thanks, Andy Quote Link to comment Share on other sites More sharing options...
Jeff Babb Posted November 30, 2011 Report Share Posted November 30, 2011 I had to repair a couple of those myself. The wiring diagram is in the literature that comes with the kit. https://dmc.wisc.edu/media/manuals/efl/sennheiser_ew100_G2.pdf Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted November 30, 2011 Report Share Posted November 30, 2011 A friend wants me to repair his cable that goes from his G2 Rx to his mixer. It's a locking TRS mini to XLR male. Does anyone know the proper wiring for this cable. Thanks, Andy Here you go. In the XLR the shield/ground goes to pins 1 & 3, positive to pin 2. In the 3.5mm, pin 2 wire goes to the tip, shield to the ground. Hint, split the shield into two legs, twist into a braid and tin them then solder a leg to pin 1 and a leg to pin 3. Lot easier then trying to wire in a jumper between them. BTW if you're trying to fix the cable with the blue collar on the xlr end that came with the G2 from Sennheiser forget it. It's a molded cable that can't be repaired. OTOH I make replacement cables for the G2/3 series that are guaranteed for life (my life, not the cables) Eric Quote Link to comment Share on other sites More sharing options...
Audio Daddyo Posted November 30, 2011 Author Report Share Posted November 30, 2011 Thanks Eric. I had a feeling you would be the first to respond. Yes I already cut off the molded cable and replacing it. I appreciate the info. Oh and I hope you have a long life. Andy Quote Link to comment Share on other sites More sharing options...
cmassey Posted November 30, 2011 Report Share Posted November 30, 2011 Yes, let's hope Eric lives much longer than his cables. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted November 30, 2011 Report Share Posted November 30, 2011 Thank you both. I can feel the love in the room but no group hugs or singing cumbayah. Eric Quote Link to comment Share on other sites More sharing options...
Jesse Watts Posted December 15, 2011 Report Share Posted December 15, 2011 Here you go. In the XLR the shield/ground goes to pins 1 & 3, positive to pin 2. In the 3.5mm, pin 2 wire goes to the tip, shield to the ground. Hint, split the shield into two legs, twist into a braid and tin them then solder a leg to pin 1 and a leg to pin 3. Lot easier then trying to wire in a jumper between them. BTW if you're trying to fix the cable with the blue collar on the xlr end that came with the G2 from Sennheiser forget it. It's a molded cable that can't be repaired. OTOH I make replacement cables for the G2/3 series that are guaranteed for life (my life, not the cables) Eric I was under the impression that on the G3 the tip is for mic level and the ring is for line with the remaining grounded. I have a made a few G3 cables like this for line in on the transmitter with no problems or level issues. I did some experimenting and used the tip as the "Hot" and saw no change in levels on the transmitter. maybe the G3's are a bit different than G2's, I couldn't find any official wiring info from Sennheiser? -Jesse Quote Link to comment Share on other sites More sharing options...
Derek H Posted December 16, 2011 Report Share Posted December 16, 2011 Hey Eric, have you found any reason one should avoid using just a standard trs 3.5mm connector with the g3/g2? Such as the right angle version from Neutrik? I realize the connection would be prone to pull out but other than that anything electrically significant? Quote Link to comment Share on other sites More sharing options...
jason porter Posted December 16, 2011 Report Share Posted December 16, 2011 I have used the right angle, no problem and no problems getting pulled out accidentally. I find the lower profile easier to deal with and makes for less possibility of the cable getting snagged. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted December 16, 2011 Report Share Posted December 16, 2011 Hey Eric, have you found any reason one should avoid using just a standard trs 3.5mm connector with the g3/g2? Such as the right angle version from Neutrik? I realize the connection would be prone to pull out but other than that anything electrically significant? You've answered your own question. NO problems continuity wise. Eric Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted December 16, 2011 Report Share Posted December 16, 2011 I was under the impression that on the G3 the tip is for mic level and the ring is for line with the remaining grounded. I have a made a few G3 cables like this for line in on the transmitter with no problems or level issues. I did some experimenting and used the tip as the "Hot" and saw no change in levels on the transmitter. maybe the G3's are a bit different than G2's, I couldn't find any official wiring info from Sennheiser? -Jesse You can only have the incomming audio feed just one connection in the 3.5TRS. If you're feeding the tx a line level "0" signal the connection should go to the ring in the 3.5 TRS to feed the proper circuit in the G2/3 tx. You can't attenuate the G2/3 mic input enough to accomodate the line level signal. I have a feeling feeding the ring input on the tx passes it through a 40-50 db pad. Eric Quote Link to comment Share on other sites More sharing options...
Jesse Watts Posted December 17, 2011 Report Share Posted December 17, 2011 You can only have the incomming audio feed just one connection in the 3.5TRS. If you're feeding the tx a line level "0" signal the connection should go to the ring in the 3.5 TRS to feed the proper circuit in the G2/3 tx. You can't attenuate the G2/3 mic input enough to accomodate the line level signal. I have a feeling feeding the ring input on the tx passes it through a 40-50 db pad. Eric That makes sense. I've grounded the tip and shield in this scenario . My only concern left is defeating the 5v mic phantom. I read that you need to use resistors to do this. I think I've had one problem because of this, using My 442's TA3 tape out to feed a G3 and 3.5mm tape out to feed the comtek (it must be a shared circuit). I'm getting heavy Comtek interference/noise with the G3 Switched on. Not a big deal but annoying none the less. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted December 18, 2011 Report Share Posted December 18, 2011 I've been using a G2 for years w/o issue along with an adjacent Comtec If usng the tip, for mic mic level, the ring is floated, for line level (and It won't take a full +4 ref.) The tip and sheild are tied. "My only concern left is defeating the 5v mic phantom." >> Not to nitpic, but the 5V, (or lower voltage) for lavs and such ain't Phantom. Pwr. Bias power (or current) is also known as 'Plug-in Pwr.' A whole differnt animal. Confusing the two can be a disaster. Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted December 18, 2011 Report Share Posted December 18, 2011 Thank you both. I can feel the love in the room but no group hugs or singing cumbayah. Eric Funny you should say that Eric. I'm seventy years old in a few weeks time and I've never felt the need to play a musical instrument but all of a sudden I have an irrepressible urge to play the ukulele banjo and I'm told that cumbayah is a good learning piece. Malcolm Davies. A.m.p.s. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted December 18, 2011 Report Share Posted December 18, 2011 Funny you should say that Eric. I'm seventy years old in a few weeks time and I've never felt the need to play a musical instrument but all of a sudden I have an irrepressible urge to play the ukulele banjo and I'm told that cumbayah is a good learning piece. Malcolm Davies. A.m.p.s. You're 70yo? Welcome to my world. Obviously neither of us look our age. Congrats on reaching middle age with such aplomb, grace & style. Eric Quote Link to comment Share on other sites More sharing options...
studiomprd Posted December 19, 2011 Report Share Posted December 19, 2011 " the 5v mic phantom. " + " also known as 'Plug-in Pwr.' " that is not phantom power. Phantom power is an industry standard for delivering DC voltage over balanced audio connections. Unbalanced power for electrit condenser mic's comes in many propriatary forms (thus all the wiring options for transmitters) of which Sony's propriatary "Plug'N Power" is but one Quote Link to comment Share on other sites More sharing options...
