Richard Ragon Posted December 7, 2011 Report Share Posted December 7, 2011 I snapped the BNC connector clean off my lectrosonics sna600 antenna this weekend while moving my cart though a doorway. I replaced it with the spare that I had. Just wondering, can these be fixed by Lectrosonics, or is just a lost cause? Thanks -Richard Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 7, 2011 Report Share Posted December 7, 2011 I'll betcha they can help you. Of course, it depends upon exactly where the damage is -- as in, did you break the fin itself where the connector lives, or just knock the connector piece off? They're quite fond of their customers. Let us know what they say. Quote Link to comment Share on other sites More sharing options...
LarryF Posted December 7, 2011 Report Share Posted December 7, 2011 Hi Richard, Take a fairly close up picture (iPhone or equivalent) of the BNC mounting area of the SNA and send to larryf@lectrosonics.com. As long as the copper traces and mounting holes aren't ripped loose it should be repairable. How handy are you with solder wick and a soldering iron? I can mail you a BNC. You must have really hit that connector! Best, Larry F I snapped the BNC connector clean off my lectrosonics sna600 antenna this weekend while moving my cart though a doorway. I replaced it with the spare that I had. Just wondering, can these be fixed by Lectrosonics, or is just a lost cause? Thanks -Richard Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 7, 2011 Report Share Posted December 7, 2011 Hi Richard, Take a fairly close up picture (iPhone or equivalent) of the BNC mounting area of the SNA and send to larryf@lectrosonics.com. As long as the copper traces and mounting holes aren't ripped loose it should be repairable. How handy are you with solder wick and a soldering iron? I can mail you a BNC. You must have really hit that connector! Best, Larry F Larry even does house calls! Quote Link to comment Share on other sites More sharing options...
r.paterson Posted December 8, 2011 Report Share Posted December 8, 2011 Hello on the topic of sna600 , I have a sna600 which the dipoles are always working loose , does anyone know of replacement nuts with nylon inserts for the sna600 ..I am in the UK..many thanks..Richard paterson Quote Link to comment Share on other sites More sharing options...
LarryF Posted December 8, 2011 Report Share Posted December 8, 2011 Hi Richard, The SNA600 has 4 frusto-conical Belleville washers under the arms and nuts to maintain constant tension on the arms over time. The two nuts have nylon collar inserts (Nyloc) to prevent them from loosening. All of this to say, they shouldn't be working loose. Are you missing some of the original pieces? I can mail you replacement parts if so. Best Regards, Larry Fisher Lectrosonics Hello on the topic of sna600 , I have a sna600 which the dipoles are always working loose , does anyone know of replacement nuts with nylon inserts for the sna600 ..I am in the UK..many thanks..Richard paterson Quote Link to comment Share on other sites More sharing options...
al mcguire Posted December 8, 2011 Report Share Posted December 8, 2011 " frusto-conical Belleville washers " http://en.wikipedia.org/wiki/Belleville_washer Quote Link to comment Share on other sites More sharing options...
LarryF Posted December 8, 2011 Report Share Posted December 8, 2011 It just describes it so exactly. "The part of a solid, such as a cone or pyramid, between two parallel planes cutting the solid, especially the section between the base and a plane parallel to the base." Cheers, Larry F " frusto-conical Belleville washers " http://en.wikipedia....lleville_washer Quote Link to comment Share on other sites More sharing options...
r.paterson Posted December 8, 2011 Report Share Posted December 8, 2011 Hello Larry I am away at moment, and will check it against a new one I have when I get back, I ent it to somene for a few months and it was never the same I asssumed the nylon had worn...if I find washer etc missing I will email you...many thanks..Richard Quote Link to comment Share on other sites More sharing options...
JonG Posted September 1, 2013 Report Share Posted September 1, 2013 I have an sna600 where the screws for the dipole wings come loose as well. It happens from constantly folding and unfolding them in and out. I just carry a small set of pliers to tighten them up. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted September 2, 2013 Report Share Posted September 2, 2013 I have an sna600 where the screws for the dipole wings come loose as well. It happens from constantly folding and unfolding them in and out. I just carry a small set of pliers to tighten them up. Mine too. I mostly use it for bag jobs, so I end of folding it alot. Quote Link to comment Share on other sites More sharing options...
sergiofucchi Posted September 2, 2013 Report Share Posted September 2, 2013 I have two SNA600 and I would know if I can modify the flow of the strips to receive also block 19. Sergio. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted September 2, 2013 Report Share Posted September 2, 2013 Probably, using this tool (many of them on the web, look for ''dipole antenna lenght'' or ''how to make a dipole ant.'' ): http://www.csgnetwork.com/antennaedcalc.html Quote Link to comment Share on other sites More sharing options...
LarryF Posted September 2, 2013 Report Share Posted September 2, 2013 I have two SNA600 and I would know if I can modify the flow of the strips to receive also block 19. Sergio. Hi Sergio, Though not listed, because the block didn't exist at the time, the SNA works well down to 470 MHz, i.e., below block 19. On the next run, the frequency markings will show that. Yours will work block 19 without the markings; just extend the arms to the maximum length. Best Regards, Larry F Lectro Quote Link to comment Share on other sites More sharing options...
sergiofucchi Posted September 2, 2013 Report Share Posted September 2, 2013 Ok. Thank You, Larry Quote Link to comment Share on other sites More sharing options...
studiomprd Posted September 3, 2013 Report Share Posted September 3, 2013 " to receive also block 19. " using it now, you cannot receive Block 19 ?? Quote Link to comment Share on other sites More sharing options...
Robert Bluemke Posted February 4, 2017 Report Share Posted February 4, 2017 Dredging this up as I need to find out what size screw is used for the adjusting screws. Thanks. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted February 5, 2017 Report Share Posted February 5, 2017 Call Lectrosonics and they will tell you and most likely will send you replacement screws for free. Quote Link to comment Share on other sites More sharing options...
WesH Posted February 6, 2017 Report Share Posted February 6, 2017 The screws that hold the adjustable element to the fixed element are #4-40 x 3/16" 100 degree flat head screws (our p/n 28528) - you should be able to get them at your local hardware store in short order. If you can afford the mail delay, contact Customer Service and we'll be glad to send you some replacements. Best, Wes Herron Lectrosonics, Inc. Quote Link to comment Share on other sites More sharing options...
Robert Bluemke Posted February 7, 2017 Report Share Posted February 7, 2017 Fantastic, thanks a lot Wes! Quote Link to comment Share on other sites More sharing options...
