berniebeaudry Posted December 15, 2011 Report Share Posted December 15, 2011 I'm making a DB15 to xlr cable for my Nomad AES in/out and having never dealt with AES pairs I want to be sure I'm doing it right. Here is the pin out: 1 RX34+ 2 RX12+ 3 RX56+ 4 RX78+ 5 RX56+ 6 TX12- 7 TX12+ 8 Ground 9 TX34- 10 TX34+ 11 RX12- 12 RX34- 13 TX56- 14 RX78- 15 RX56- There is receive (RX) and transmit (TX) plus and minus for each unique number. So how do they correspond to the pins of the xlr? Thanks, Bernie Quote Link to comment Share on other sites More sharing options...
Jim Gilchrist Posted December 15, 2011 Report Share Posted December 15, 2011 I'm making a DB15 to xlr cable for my Nomad AES in/out and having never dealt with AES pairs I want to be sure I'm doing it right. Here is the pin out: 1 RX34+ 2 RX12+ 3 RX56+ 4 RX78+ 5 RX56+ 6 TX12- 7 TX12+ 8 Ground 9 TX34- 10 TX34+ 11 RX12- 12 RX34- 13 TX56- 14 RX78- 15 RX56- There is receive (RX) and transmit (TX) plus and minus for each unique number. So how do they correspond to the pins of the xlr? Thanks, Bernie Hey, Bernie. The - line on pin 3, the + line on pin 2. Happy fabricating. Best regards, Jim Quote Link to comment Share on other sites More sharing options...
rich Posted December 15, 2011 Report Share Posted December 15, 2011 Bear in mind, if you have copied the pin outs from the nomad preliminary manual, that pins 11 and 12 should be swapped. The layout should be obvious when you look at the DB15 connector. Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted December 15, 2011 Author Report Share Posted December 15, 2011 Hey, Bernie. The - line on pin 3, the + line on pin 2. Happy fabricating. Best regards, Jim Thanks Jim, that's what I was thinking. Then of course pin one goes to the ground, correct? So the sends are the AES outs done in pairs ie: terminating in four male xlrs for a total of 8 AES outs , and the returns are the four pairs of AES inputs terminating in female xlrs. Since I know nothing about AES wiring, am I understanding this correctly? For now I just want to hook up one pair to do AES into my D-4 camera hop. So I should end up with just one cable terminating in a female TA3 going into the first input of my D-4 transmitter. Thanks, Bernie Bear in mind, if you have copied the pin outs from the nomad preliminary manual, that pins 11 and 12 should be swapped. The layout should be obvious when you look at the DB15 connector. I saw that, Thank you! Quote Link to comment Share on other sites More sharing options...
Jim Gilchrist Posted December 15, 2011 Report Share Posted December 15, 2011 Yes, Bernie, that's correct. So connect the DB-15 pin 8 to pin 1 of your TA and the + of whatever pair you pick to use to pin 2 and the - of that pair to pin 3. Remember that pins 2 and 3's positions are flipped in TA connectors, 2 where 3 is in a standard XLR and vice versa. Best regards, Jim Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted December 16, 2011 Author Report Share Posted December 16, 2011 Yes, Bernie, that's correct. So connect the DB-15 pin 8 to pin 1 of your TA and the + of whatever pair you pick to use to pin 2 and the - of that pair to pin 3. Remember that pins 2 and 3's positions are flipped in TA connectors, 2 where 3 is in a standard XLR and vice versa. Best regards, Jim Thanks Jim! Its all making sense now! Best, Bernie Quote Link to comment Share on other sites More sharing options...
softstar86 Posted March 9, 2015 Report Share Posted March 9, 2015 How to connect to ZAXCOM RX12 (TA5M) Quote Link to comment Share on other sites More sharing options...
