Rachel Cameron Posted January 5, 2012 Report Share Posted January 5, 2012 I have to feed two Sony EX-1's with my 442. My question is: Do both 442 outputs (the XLR and the TA3M) work simultaneously? If so, I can just use an adaptor cable for the B camera, right? If not, how can I do this? Thanks for any input you guys can offer. Rachel Quote Link to comment Share on other sites More sharing options...
Marc Hoppe Posted January 5, 2012 Report Share Posted January 5, 2012 Yes, all the outputs work simultaneously. The 10 pin and the xlr outs have external mic/line switches, but the TA3 outputs mic line switch is menu driven. By default it is set to line level. Marc Quote Link to comment Share on other sites More sharing options...
Chris McCallum Posted January 5, 2012 Report Share Posted January 5, 2012 I have done exactly this in the past and used the 10 pin and the XLR outputs. They are switchable between line and -10 individually Quote Link to comment Share on other sites More sharing options...
Richard Nault Posted January 5, 2012 Report Share Posted January 5, 2012 Very handy to have 2 cables available: your hirose output, and an either XLR or TA3 output cable and then have your wireless hop use the other output (the unused TA3 or XLR)... Then you have the option of feeding 3 cameras if needed. Always good to have options! Rich Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 5, 2012 Report Share Posted January 5, 2012 " Do both 442 outputs (the XLR and the TA3M) work simultaneously? " + " with my 442. " What does the manual say?? A professional really knows their equipment. Quote Link to comment Share on other sites More sharing options...
John Steigerwald Posted January 5, 2012 Report Share Posted January 5, 2012 " Do both 442 outputs (the XLR and the TA3M) work simultaneously? " + " with my 442. " What does the manual say?? A professional really knows their equipment. You might want to check your forum settings, it appears some posts may not be showing for you. Quote Link to comment Share on other sites More sharing options...
