fatfatjames Posted January 14, 2012 Report Share Posted January 14, 2012 Hi does anyone know which are the pin for remote roll in the serial/gpi port of the fusion? Thanks Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 14, 2012 Report Share Posted January 14, 2012 Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted January 15, 2012 Report Share Posted January 15, 2012 I checked and could not find the serial port pinout in the manual (though it's mentioned on page 57). This would mean a call to Zaxcom tech support. Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted January 16, 2012 Author Report Share Posted January 16, 2012 HI Marc do you know who i should look for? Quote Link to comment Share on other sites More sharing options...
Michael Posted January 16, 2012 Report Share Posted January 16, 2012 If you get the answer could you post it here? I was looking at buildIng something similar a while ago but you know how it goes, something else is just that bit more important. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted January 16, 2012 Report Share Posted January 16, 2012 HI Marc do you know who i should look for? When you access Tech Support, there'll be voice messages to direct you. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted January 17, 2012 Report Share Posted January 17, 2012 The main U.S. number should get you through to Tech Support: (973) 835-5000 Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted January 19, 2012 Author Report Share Posted January 19, 2012 OK time to share, from Howard: "Connect a toggle switch between pin 4 (GPI-IN) and pin 5 (GND) and adjust your perferred polarity in the SETUP::OPERATING_MODE page. (and turn GPI1 remote Roll ON too)." Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 19, 2012 Report Share Posted January 19, 2012 Quote Link to comment Share on other sites More sharing options...
Whit Norris Posted January 20, 2012 Report Share Posted January 20, 2012 Hey James, The setting in the Operating Mode Menu setting should be GPi1 Remote Roll should be set for Rising Edge and of course as you mentioned Serial Remote set to ON. Sorry I missed your posting or I could have told you how mine was wired. Good Luck! Cheers, Whit Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted January 22, 2012 Author Report Share Posted January 22, 2012 Norris how did you do yours? i have not fix anything yet... ask it is Lunar New Year period now in Singapore and most of the shops are not open... maybe you can share how you do your so that i can refer to it when i am doing your... Quote Link to comment Share on other sites More sharing options...
Whit Norris Posted January 22, 2012 Report Share Posted January 22, 2012 I am using the CL-1 from Sound Devices. I roll the SD as my backup. The CL-1 rolls the Deva and my 744T. It will not roll the Deva with out the Sound Devices connected. So I just built the cable. Sorry not much help on building the remote. Whit Quote Link to comment Share on other sites More sharing options...
greg sextro Posted January 22, 2012 Report Share Posted January 22, 2012 James, Do you solder? if i've read all this correctly, all you really need is a simple toggle switch (either normally open or closed) and wire it inline of the 2 leads from the fusion. You'll need a 9 pin connector for the fusion. don't know if they have radio shacks (or hopefully a better equivalent) in Singapore, but you can house the toggle switch in a small "project box" and place the switch where you want it on your cart. Quote Link to comment Share on other sites More sharing options...
Todd Weaver Posted January 9, 2013 Report Share Posted January 9, 2013 I'm about to undertake the design of a unit that will roll zaxcom, fostex, sound devices, boom recorder, and movie slate with one switch. Should be very cool. I'll post as to the progress. Quote Link to comment Share on other sites More sharing options...
Michael Posted January 9, 2013 Report Share Posted January 9, 2013 Am in the process of doing the same. Based mine around an arduino board Progressing at a glacial pace due to life. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted January 9, 2013 Report Share Posted January 9, 2013 Speaking of remotes, here's one I designed & built for the Fostex D15 & D25 studio DAT machines. Probably a bit of overkill for today. P.S. it's for sale if anyone needs/wants it. Quote Link to comment Share on other sites More sharing options...
