mlemaudit Posted October 3, 2007 Report Posted October 3, 2007 Hi I am trying to put together a simple set-up with a boom into the sound devices 302 that goes into the mbox to record in boom recorder. Simple yes indeed but my am trying to adjust the 1k at 0Vu on the sound device with the boom recorder at -12 or -18 ddb but I can't because the mbox input levels are at the minumum and it peaks in boom recorder at 0dbfs. The only way I can reduce the level is to press the pad button at the back of the mbox but it's at -22.5dbsf so it is not accurate enough. I think I can attenuate the XLR output level on the 302. I'll try that for now and see... Quote
Sergio Sanmiguel Posted October 3, 2007 Report Posted October 3, 2007 Try mic level out off the SD302 (internal setup menu) & into your Mbox at mic level input too... Quote
