   I have been using AES outputs quite a bit with 664 and mostly XDCAM 700/800's and pix 240. I have been using a regular analog 15 foot snake with good luck. However, anytime I lengthen the snake I start running into problems. Obviously the impedance of the analog cables/connectors is not ideal.
-Has anyone made or sourced 110ohm snakes for distro?
-Anyone running Transformers and coax for distro? What are your thoughts?
-What does SD recommend for AES cabling and Distro for 25-50foot lengths?
baretta: "
-Has anyone made or sourced 110ohm snakes for distro?  YES, many many (there is another recent thread about AES mic cable)
-Anyone running Transformers and coax for distro? What are your thoughts?  maybe, but why ?
-What does SD recommend for AES cabling and Distro for 25-50foot lengths?  SD is easy to contact.
