GoPro Hero & TC For Synch
I would think you will need to match A-Cam unless you are shooting only with GoPros.  If production is running multiple frame rates across different cameras, you need to work out with post what they synch plan will be, since they will presumably be doing some sort of pull-down to intermingle the footage.
More likely, they will just run everything at 23.976 and that's what you should use.  It's news to me that they would use anything else.
