Hi SonoCaro,
Take all of them.  Las Vegas is a constantly shifting radio environment, and can change drastically with small movements around the Strip. It's good to have lots of flexibility.   Scan in every location!
Also have fun!
Brent Calkin
Ignore Mr. SENATOR Misinformation Station.  He's gone past his usual useless prattle and has shifted into malicious disinformation by posting blocks that you do not have, but are likely no better or worse than yours...
Check this thread
Brent Calkin
Posted (edited)
Free: " but are likely no better or worse than yours... "
based on ..?
but it is not disinformation...
they are available in Las Vegas, and she can use them;  but as everyone who posts the same (tired) what blocks work question, actually, they all really plan to take, and use what they already have.
OK, then she can use Bl 21, Bl 22, and Bl 26...
they are also available in Las Vegas.
Edited by studiomprd
In a casino or in the Las Vegas area? Casinos (and the strip) are a wildcard. There is so much going on between their stage shows and the gambling related stuff.
If you're off the strip, you should be ok with what you have. I'm sure one of the locals will eventually chime in. If I remember right 21 and 26 were very usable.
