David Waelder Posted May 26, 2021 Report Posted May 26, 2021 We have a housing built by Chinhda to hold two monitors. A sheet of clear Lexan provides protection for the screens from on-set hazards. There is a built-in speaker with volume control that may be used to monitor set activity during lighting. While the speaker is powered up, a meter tracks the voltage of the power supply. The speaker may be switched off for takes or simply reduced to no level to retain the power readout. On the left side there is a hinge to hold a clipboard for sides. It can fold against the monitors while moving or storing the cart and the tension of the hinge is adjustable. Please let me know if you are interested: David Waelder - davidwae@earthlink.net As with other items in the shop, all proceeds go to Chinhda's daughter, Kathy. Quote
