Nicole Hankerson Posted March 1, 2012 Report Posted March 1, 2012 Tascam Dr-40 anyone here using one? Are you able to name files and if so how easy/fast is it on the fly? Thanks for any input. I did read the manual but it doesn't go into much details but again I could have missed/overlooked info. Nicole Quote
ShubiSnax Posted March 1, 2012 Report Posted March 1, 2012 Menu: Others: File Name You have the option of naming by word or date. Example, you name your file "door close" Your file looks like this: door close_0001 There is also an option there to reset the track count. Quote
Nicole Hankerson Posted March 1, 2012 Author Report Posted March 1, 2012 Awesome cool. Thanks for the info. Seems like this recorder will do the trick. Nicole Quote
Rick Reineke Posted March 1, 2012 Report Posted March 1, 2012 Naming by word is (as I recall) limited to six prefix alphanumeric characters which can be ot upper and lower case.. for instance Tascam_0001.wav, whereas in the date mode: today's 1st file would start with "120301_0001.wav", if reset to start in an empty folder. Quote
Nicole Hankerson Posted March 2, 2012 Author Report Posted March 2, 2012 They ended up having one in stock at Guitar Center so I tested it out and it worked perfect for what I needed. File naming works great and can easily be configured to work in fast situations. Thanks for your help. Nicole Quote
