Zaxcom CameraLink receives TC OK but no TC stamp on files
This was odd behavior that happened today.  i wanted to provide a client with an entire recording of an event for backup purposes. TC is jamming regularly like normal. i was able to pull the file into protools and use another file from the recorder to restamp tc. the last file in the list below is me putting the card back in and suddenly the tc stamped properly? zaxcom maxx and CL block 22
ran tests today - the only way i could consistently reproduce this problem is BDS powering all units at the same time. rarely the CL would timestamp correctly. only files on micro SD were affected, not files on lav transmitters receiving tc from CL. once i powered maxx unswitched and powered first allowing to boot up full it seemed to fix this problem
