osa Posted January 16, 2022 Report Posted January 16, 2022 I am working on a radio play and per clients request i made videos that are audio only with timecode window burns of all the production sound we recorded. I used davinci resolve and able to get thru it enough to be dangerous, and these were all large takes so not to terrible to do for this project ( a few large takes vs a bunch of short takes), but i was curious if there was another way to approach this to make video window burns of audio only? -Ken Quote
Bouke Posted January 17, 2022 Report Posted January 17, 2022 Sure. (Resolve seems a sledgehammer for this kind of work.) https://www.videotoolshed.com/product/make-transcriber-files/ Bouke Quote
osa Posted January 18, 2022 Author Report Posted January 18, 2022 21 hours ago, Bouke said: Sure. (Resolve seems a sledgehammer for this kind of work.) https://www.videotoolshed.com/product/make-transcriber-files/ Bouke I use this for transcriber files, but if i understood correctly, doesnt it require to start with video vs turning audio only into video if i am not mistaken? Quote
Bouke Posted January 18, 2022 Report Posted January 18, 2022 I don't know what version you're on, but since a couple of years, it can make video from audio only. (With a custom bg.) Do read the manual! Bouke Quote
osa Posted January 18, 2022 Author Report Posted January 18, 2022 9 hours ago, Bouke said: I don't know what version you're on, but since a couple of years, it can make video from audio only. (With a custom bg.) Do read the manual! Bouke Brilliant this is the one! I bought it a few years ago so indeed i am due to upgrade, thanks for the info Quote
Bouke Posted January 18, 2022 Report Posted January 18, 2022 Check your version, if the first number is the same, upgrade is just 'update', thus free of charge. (Under 'about' shows you the version also...) Anyways, toy with the demo. (If you're lucky and have a 3.x version, it 'should' update automagically when you run the demo.) Bouke Quote
osa Posted January 18, 2022 Author Report Posted January 18, 2022 Thank you this absolutely was the ticket, the update worked and my previous serial no popped right in automatically. Ffmpeg auto install was brilliant. time code window is perfect for this purpose. I am sure many other uses in the future i.e. a corporate client of mine making poscasts will appreciate this process as well. Quote
Bouke Posted January 18, 2022 Report Posted January 18, 2022 Glad it works for you. Do read the manual about how to make a 'branded' custom video background! Also, DO set the FPS right! BWF as input can be interpreted multiple ways! (DF / NDF being the most important, and 23.976 is ALWAYS non-drop (sadly.) Quote
