David Medina Posted June 10 Report Share Posted June 10 Hi there. My sd 664 is showing only a yellow led light and the screen is white. Can anybody tell me what can i do by myslef before sending it to support centre? Im in Africa so ita gonna be a nightmare sending it to europe or the us. Quote Link to comment Share on other sites More sharing options...
PMC Posted June 11 Report Share Posted June 11 Last year my SD664 screen stopped displaying anything. The rest of the unit worked but of course unusable in the field. I sent it in to SD. They said the ribbon cable from the circuit board to the display was dislodged. Yes, my unit has had some rough handling over the past 10 to 12 years in the field. Maybe you can lift the lid, so to speak, and check out the ribnon cable. Quote Link to comment Share on other sites More sharing options...
David Medina Posted June 11 Author Report Share Posted June 11 10 hours ago, PMC said: Last year my SD664 screen stopped displaying anything. The rest of the unit worked but of course unusable in the field. I sent it in to SD. They said the ribbon cable from the circuit board to the display was dislodged. Yes, my unit has had some rough handling over the past 10 to 12 years in the field. Maybe you can lift the lid, so to speak, and check out the ribnon cable. Thanks for your answer. I opened it but everything seem in order. I guess ill have to send it Quote Link to comment Share on other sites More sharing options...
PMC Posted June 11 Report Share Posted June 11 They have a reasonable loaner program but I only live 200 miles away from the factory so did a drop-off and pick-up. Quote Link to comment Share on other sites More sharing options...
