I have a job coming up that is Sound only where I will have a producer friend taking notes on a clipboard, just wanted to see if there was a clever way to mount or position a zaxcom erx on a clipboard to listen/take notes/see tc clock ergonomically?
If you use a case with a clip you could easily just clip it to the board. When I used ERXs, I’d keep them in the Orca cases designed for them, and they came with belt clips on the back. Setwear also makes something that fits them well and has a belt clip. I’ve seen plenty of Script Sups clip them to their boards and use them as IFB as well as TC readouts for note taking.
This was great I remembered i did have an older erx case in storage maybe a k-tek with fogged clear plastic? had stopped using a while back. Clipped to top of clipboard perfect and i folded fogged plastic inside the case leaving erx screen exposed.
