jwill Posted June 21, 2023 Report Posted June 21, 2023 Just came off a gig where the 2 cameras were Ursa minis, the menus said it was set for line level, when I listened to return it was buzzing and sounded like it was clipping, I just dialed back so it didn't sound like it was clipping. I of course recorded everything, gave them a L/R feed to camera and ISO record. TC was provided to cam a via my tc snake, and cam b by tentacle and IFBlue scratch as well as using TC slate for each take. I asked several times for playback from camera as I noticed returns had a bad buzz, DP said don't worry, just make sure you record everything in your mixer! Anyone else have issues with the URSA Mini? Quote
Jason Walle Posted August 31, 2023 Report Posted August 31, 2023 We own and use 2 URSA 4.6k G2s all the time with our company. You said "the menus said it was set for line level." Just confirming you mean the physical switch on the camera body right? You can't set mic/line/aes in the menu system. I've never run into an issue with sound going into our URSAs. We used to run Lectro LRs to them but have switched to using IFBlues for scratch since the audio 99% of the time comes from the mixer. Quote
