Michael McQueen Posted November 11, 2011 Report Share Posted November 11, 2011 I'm looking for a good quality receiver that can go into the low 100mhz range. i do a good bit of work with a new aircraft company and one of the things I am often asked to do is record the sounds of the telemetry communication with the aircraft and then communication from aircraft to ground control. currently i use 2 way communication radios and just run the headphone jack into an xlr. it works, but i'd like to find something a bit better suited for both my bag and when mounting to camera. for camera mounting i've set up a bracket1 ex with velcro the strap mount. but on the other hand, the radios i use now work pretty good and they retail for around $250. and the battery packs are rechargeable and run for a long time. but if there were something like a g3 sized rx that would be perfect. i've searched many of the inderwebz but haven't really found anything, thus turning to you guys. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 11, 2011 Report Share Posted November 11, 2011 " 2 way communication radios " Shortwave radios, there are many and all shapes, sizes, and prices. These are available from "Ham Radio usual suspects", and also some, especially small ones are available from camera-electronics outlets and dealerships. BTW, interestingly, radios up to about 50 MHz are called HF radios, with VHF beginning at about 50 MHz. Quote Link to comment Share on other sites More sharing options...
