Jakobk Posted October 30, 2018 Report Posted October 30, 2018 Has anyone of you done one? Planning to do some. Short ones, lemo to xlr (from there, if needed i can extend and adapt...) I would put the resistors in the xlr plug, should work, no? Why is the "loop" from ground, around audio? Quote
rich Posted October 30, 2018 Report Posted October 30, 2018 ive made a few of these. they work fine. just make sure you get small enough resistors to make your life easy when wiring the XLR. and yes. put the resistors in the XLR. the loop around the audio signal is the shield of the cable. Quote
Jakobk Posted October 30, 2018 Author Report Posted October 30, 2018 37 minutes ago, rich said: the loop around the audio signal is the shield of the cable. Thank you! That makes sense of course! Quote
