DaFlo Posted August 3, 2021 Report Posted August 3, 2021 Looking for help with a Betso SBox-1, which I bought second hand. I press the buttons to turn it on, and the "turning on" info comes on, but then it stops. After that, I cannot interact with the buttons at all, unless I take out the batteries, and put it back in, where I can only turn it on before it turns off again. Does anyone have a Betso SBox-1 that has encountered this issue, and knows how to fix it? Quote
codyman Posted August 3, 2021 Report Posted August 3, 2021 What batteries are you using, NiMH? I've found that the Betso door is extremely picky with those for some reason. Try some alkalines or lithiums and see if that makes a difference. Quote
Derek H Posted August 3, 2021 Report Posted August 3, 2021 Yeah the battery door sucks on these. The way they put the label sticker on NiMH AAs means that with this unit you don’t get a reliable electrical connection. They really need spring contacts. stick to alkaline or lithium for Betso boxes. Quote
