Wyatt Tuzo Posted January 8 Report Share Posted January 8 This may be a long shot, but I'm looking for someone who may have easy access to an A10 Rack (that is currently not in a rack), who would be willing to remove the top cover to photograph the inside. Specifically, I'm thinking of embarking on a mod to make one of these accommodate the Shure ADX5D's, but would like to see the internal routing of the antenna distro before buying. This modification would involve removing the chassis-mounted SMA connectors and replacing them with grommets, allowing direct RF leads to be run in their place. Thanks in advance! Wyatt Quote Link to comment Share on other sites More sharing options...
Patrick Farrell Posted January 9 Report Share Posted January 9 Hey Wyatt, Just curious- are you saying they don't work together in the stock configuration? Quote Link to comment Share on other sites More sharing options...
Wyatt Tuzo Posted January 9 Author Report Share Posted January 9 As published, the ADX5D's faceplate is 88mm wide, while the a10 rack has an available 84.4mm between SMA connectors. Losing the SMA's should make up the needed 3.6mm. I'm just curious as to the internal topology before going out on a limb for purchase. Quote Link to comment Share on other sites More sharing options...
Wyatt Tuzo Posted January 11 Author Report Share Posted January 11 While I'd still prefer to remove the SMA's altogether, another option that is presenting would be to machine a custom slot-receiver spacer with cut-outs to accommodate the SMA connectors. This will require an internal DB25 spacer as well (as seen here): Again, my preferred route would be to remove the SMA connectors altogether, but I need to make sure that I am able to maintain the RF connection integrity. If the SMA's are PCB mounted directly behind the faceplate, this doesn't leave me with many options for strain relief when replacing with cables. So that, in essence, is what I'm trying to get to the bottom of if anyone has information that could help. SD has (understandably) denied my request for technical drawings or photos. Thanks! Quote Link to comment Share on other sites More sharing options...
Trey LaCroix Posted January 20 Report Share Posted January 20 On 1/11/2022 at 7:54 AM, Wyatt Tuzo said: While I'd still prefer to remove the SMA's altogether, another option that is presenting would be to machine a custom slot-receiver spacer with cut-outs to accommodate the SMA connectors. This will require an internal DB25 spacer as well (as seen here): Again, my preferred route would be to remove the SMA connectors altogether, but I need to make sure that I am able to maintain the RF connection integrity. If the SMA's are PCB mounted directly behind the faceplate, this doesn't leave me with many options for strain relief when replacing with cables. So that, in essence, is what I'm trying to get to the bottom of if anyone has information that could help. SD has (understandably) denied my request for technical drawings or photos. Thanks! Let me know if you try any of these Wyatt. I’m trying to find a way to get at least one Shure in my A-10 rack. Quote Link to comment Share on other sites More sharing options...
Wyatt Tuzo Posted January 20 Author Report Share Posted January 20 2 hours ago, Trey LaCroix said: Let me know if you try any of these Wyatt. I’m trying to find a way to get at least one Shure in my A-10 rack. I have a LOT of information forthcoming (Next week-ish?). Stay tuned. I will likely start a new thread. Quote Link to comment Share on other sites More sharing options...
