Jon Mendel Sound Posted September 2, 2023 Report Posted September 2, 2023 Hey all, I'm looking for recommendations or advice on the best way to combine 4 SMA antenna signals from (2 additional RX's not in slot), inputting into 2 MCX into the antenna aux in the SL2? Can this be done with a simple splitter or a cable made? Thanks Jon Quote
IronFilm Posted September 3, 2023 Report Posted September 3, 2023 You're wanting take the RF outputs from the SL2 into 2x receivers? (note: you've got inputting/outputting back to front) Using a passive splitter (such as from Mini-Circuits), you'll get a drop in signal strength due to splitting it up, but it should probably be workable and not too bad. (feeding it to 3x RX though? I'd probably rather not do that, and would definitely not do it for 4x RX! You want then an active RF distro) Quote
