Beelieve Posted April 5, 2025 Report Posted April 5, 2025 I bought this used smqv a few years back and just found out I'm not able to switch step size from 100khz to 25khz when pressing 3 buttons together, is there a potential reason for this? Like older versions? or do I need any firmware updates? IMG_0543.mov Quote
Matthew Steel Posted April 7, 2025 Report Posted April 7, 2025 You are right, it does look like 25kHz mode was a feature added in later firmware versions. I think the firmware version is shown at normal power on, which I didn't notice in your video. https://lectrosonics.com/firmware-history-2-0-3-0-6-5-series-firmware-revision-history/ Quote
ProSound Posted April 7, 2025 Report Posted April 7, 2025 Need to go back to service center for firmware update you cannot do the update yourself as it needs a recalibration after update Quote
