hi all (and Tom Duffy),
I just bought a Tascam DR 10 CH with Shure connectors.
I want to use it stand alone, without transmitter.
I tried it with a Shure WL93, but after switching the 'bias on/off' switch,
to 'off' I only hear sound for a few seconds and then it is gone.
I realise that it should be 'on'. Model is switched to 'Shure'.
Any idea what could be wrong?  the recorder and lav are new.
battery too.
Thanks, Alex
Most lavaliere mics typically need some kind of power (usually 3-5 volts bias current) Not to be confused w/ Phantom Power.  I don't know if that recorder supplies the bias voltage directly or gets it from a wireless transmitter.. Try it with the bias 'on'.
