I've been trying to resolve an issue on a shoot where I've been getting interference on my wireless boom setup. I'm using  2 x Schoeps CMC/MK into Lectro HM  and UC400A on block 24. It doesn't seem to matter what channels are selected but it only occurs on the HM not the UC400A. I've tried an alternative HM but the problem persists which sounds like an induced low frequency buzz like you might get from a light on a dimmer. The only piece of camera gear that I haven't come across before is a cine RT focus bug - its only on the B camera and when we use the A camera only there is no problem. Has anyone else experienced similar issues ? Thanks in advance.
Hi Mark I came across the following in the manual and had the 1st AC try this setting but it didn't seem to make a difference to the interference.
Worth noting though !
SONIC SAVER
The CINE RT system incorporates advanced algorithms to ensure an absolute minimum of audio interference. Engaging Sonic Saver reduces the volume level of the BASE ultrasonicsignal. For use only in the extremely rare instance that a microphone picks up audio interfer- ence from the BASE or BUG(S).
Press the SONIC SAVER TOUCH KEY to engage SONIC SAVER (and see the sound recordist smile for once).
Important: Reduced ping volume will result in reduced effective range of the BASE sensor.
Note: This button will display a green border (and a smiling Sound Person) when Sonic Saver mode is engaged.
He also tried different RF channels but no difference. The strangest thing to me is that it only affects the HM (s) not the UC400A all other things being equal. I guess the UC400A case may be a slightly better shield.
Does proximity of the TX to the focus rig change the sound (like make it worse)?  How about the the RX?  I assume the 400A is cabled to the boom/mic?  Have you tried a diff boom cable with the HM?  How about the HM plugged directly into the mic, bypassing the boom cable?
