Johnny Karlsson Posted September 8, 2019 Report Posted September 8, 2019 I've been trying to find this by searching the web, Lectro's home page, and here... looking for the part that sits around the XLR connector on the plug-on transmitters. Is this something that could be picked up at a local hardware store? Anyone know the part number, or proper name/specs? (yes, a call to Lectro on Monday, but this went missing today, and I'm shooting tomorrow as well) Thanks in advance! Quote
LarryF Posted September 8, 2019 Report Posted September 8, 2019 That spring washer is an OEM part only. For a temporary fix, wrap a rubber band (s) around the XLR and try the mic tightness. Adjust the amount of rubber until the mic to XLR is just snug. The rubber should be almost loose around the XLR to get the maximum springiness. Should get you by until Lectro can mail you a washer. Best Regards, Larry Fisher Quote
Johnny Karlsson Posted September 8, 2019 Author Report Posted September 8, 2019 1 hour ago, LarryF said: That spring washer is an OEM part only. For a temporary fix, wrap a rubber band (s) around the XLR and try the mic tightness. Adjust the amount of rubber until the mic to XLR is just snug. The rubber should be almost loose around the XLR to get the maximum springiness. Should get you by until Lectro can mail you a washer. Best Regards, Larry Fisher Thank You, sir! Quote
