osa Posted February 22 Report Share Posted February 22 A long shot here but… amp is fried on this powered speaker i used to use in the field, and at one time there was repair services for what must have been a common problem with these powered speaker modules. I sat so long on the repair that repair kits or repair services seem no longer available. Anyone here ever replace a powered amp module in a speaker? Would still like to try n repair even with dif amp manufacturer or convert to passive speaker Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted February 24 Report Share Posted February 24 Haven't done what you're asking but Parts Express has lots of speakers and speaker parts. https://www.parts-express.com Quote Link to comment Share on other sites More sharing options...
osa Posted February 24 Author Report Share Posted February 24 5 hours ago, berniebeaudry said: Haven't done what you're asking but Parts Express has lots of speakers and speaker parts. https://www.parts-express.com Cool thank you - the closest thing I could find was an instructables link how to troubleshoot active speaker amplifiers, replace bad capacitors, power supplies etc So parts express will come in handy Quote Link to comment Share on other sites More sharing options...
gabe Posted March 15 Report Share Posted March 15 On 2/22/2022 at 2:19 PM, osa said: A long shot here but… amp is fried on this powered speaker i used to use in the field, and at one time there was repair services for what must have been a common problem with these powered speaker modules. I sat so long on the repair that repair kits or repair services seem no longer available. Anyone here ever replace a powered amp module in a speaker? Would still like to try n repair even with dif amp manufacturer or convert to passive speaker Check this board out: https://www.ebay.com/itm/254168587955 I used this to replace the amp on the M-Audio GSR 12. It works with the existing wire harness except for the LED logo light which I need to modify the connector. All you have to do is un-loop the wires from the magnet in the enclosure where the amp goes and this amp will fit in without any issues. I did remove the 12 inch driver to remove the wires. This amp board is slightly shorter in length and wider than the stock amp board. IMG_4387.HEIC Quote Link to comment Share on other sites More sharing options...
