hello hive mind.
Im setting up a small laptop DAW with REAPER and was thinking about using my MixPre 10-2.
When  I plug into the Mixpre USB C port from my USB A on my computer The mixpre doesnt show up even as a 2x2 device in windows.
Im running the mixpre from a 240-12v .
I have downloaded the ASIO mixpre driver  but the mixpre which is windows compliant ? shhould show up as 2x2.
I can go back to running my  yamaha micpre box via ADAT into my ferro fish and going into ethernet but was trying to make a tiny rig.
Any thoughts
thanks Ant
31 minutes ago, Throwback said:
Stating the obvious, but you do have System/USB-C set as 'Audio' not 'Power only' don't you?
Roland
The only USB function under system i can see is Normal or stereo  out......
The Mixpre 10 can not be powered by USB
Does your Windows computer installation support usb-c?
The usb-c to usb-a adapter doesnt change the protocol of the mixpre (usb-c).
Maybe you just need to install a driver...
Franky
