Jon Mendel Sound Posted August 28, 2023 Report Share Posted August 28, 2023 Hi all, Curious what are people's favorite stereo pair mic setups specifically for audience laughter tracks? I have a gig in a month for some comedy recording, and have Schoeps CMC MK4 in a pair as well as Oktava Cardioids in a pair at my disposal. Also have miniCMITs and MKH50s in pairs but my brain went caridoid for this use. ORTF? X/Y? What's the best for laughter? I thought a pair at the front of the stage and then one around the middle or rear would be good locations for my mics. Thanks for any tips Jon Quote Link to comment Share on other sites More sharing options...
henrimic Posted August 28, 2023 Report Share Posted August 28, 2023 I recorded a lot of these kind of shows years ago. Instead of stereo pairs, I did use a lot of spot mics at different places around the audience. The more mics, the best results you obtain. The thing is that if you just have a main pair and someone talks or make noise just under it, you are screwed. Also, with more mikes at different distances, you can spot some laughs and have a variety of width and options. Quote Link to comment Share on other sites More sharing options...
Derek H Posted August 29, 2023 Report Share Posted August 29, 2023 2 hours ago, henrimic said: I recorded a lot of these kind of shows years ago. Instead of stereo pairs, I did use a lot of spot mics at different places around the audience. The more mics, the best results you obtain. The thing is that if you just have a main pair and someone talks or make noise just under it, you are screwed. Also, with more mikes at different distances, you can spot some laughs and have a variety of width and options. Sounds like your approach was to disregard any kind of spatial relationship or specific stereo configuration and just go for a good blended coverage of the audience? Quote Link to comment Share on other sites More sharing options...
henrimic Posted August 29, 2023 Report Share Posted August 29, 2023 Exactly. The idea is also to get rid of the PA system. You can always create a sense of spaciousness by panning the different mics. Quote Link to comment Share on other sites More sharing options...
Mungo Posted August 29, 2023 Report Share Posted August 29, 2023 2 hours ago, henrimic said: Exactly. The idea is also to get rid of the PA system. You can always create a sense of spaciousness by panning the different mics. Most sound people I know follow the same approach. Main challenge is to get as little PA sound as possible. They end up hanging some 416s straight above the audience at different spots. Quote Link to comment Share on other sites More sharing options...
