chris_bollard Posted November 19, 2010 Report Posted November 19, 2010 Hi all Does anyone have definitive wiring info to put together at TA5 to Stereoline input cable. Want to trim down my sundry cables with new 788T. I'm currently using adaptors to get where I need to be and was going to knock up something on the weekend Any info would be great Chris Quote
Eric Toline Posted November 19, 2010 Report Posted November 19, 2010 Hi all Does anyone have definitive wiring info to put together at TA5 to Stereoline input cable. Want to trim down my sundry cables with new 788T. I'm currently using adaptors to get where I need to be and was going to knock up something on the weekend Any info would be great Chris There is a users manual with input wiring on the Zax website. It's the Stereoline transmitter users manual-39.pdf. While it does offer various wiring diagrams for different mics and line inputs, none of the pins are numbered although the wiring is most likely shown from the solder side the keyway will help to orient which pin is which. Eric Quote
chris_bollard Posted November 19, 2010 Author Report Posted November 19, 2010 Eric Thanks but already been there and as you point out NOT terribly clear. I am hoping for pin to pin detail Quote
Eric Toline Posted November 19, 2010 Report Posted November 19, 2010 Eric Thanks but already been there and as you point out NOT terribly clear. I am hoping for pin to pin detail What are you feeding the tx from, a lav wired for Lectro? If so which mic? Eric Quote
Andy P Posted November 19, 2010 Report Posted November 19, 2010 Hey Chris, here's how's mine wired, from a 442 at Line level. XLRL Pin 1 --- TA5 Pin 1 XLRL Pin 2 --- TA5 Pin 3 XLRL Pin 3 --- TA5 Pin 2 XLRR Pin 1 --- TA5 Pin 1 XLRR Pin 2 --- TA5 Pin 4 XLRR Pin 3 --- TA5 Pin 5 Double checked on two different cables. Mind them fumes;-) Quote
r.paterson Posted November 19, 2010 Report Posted November 19, 2010 hello yes you need to double check ta5 for sta150 it is pin 4 ch2 -ve and pin 5 +ve not the same as a normal 5 pin stereo mic wiring, cable i received was pin 4 +ve and pin 5-ve and ch1 and ch 2 were out of phase, in zaxcom manual sta ta5 is pin1 earth, pin 2 ch +ve, pin 3-ve, pin 4 ch2-ve, and pin 5 ch2 +ve..while we are on zaxcom wiring anyone know what wiring is for tc/audio 3.5mm socket on sta150 cant find it anywhere..is it tip=ch1 only and you cant monitor ch2 at all?, posted on zaxcom users group but no reply so far.. thanks richard Quote
r.paterson Posted November 19, 2010 Report Posted November 19, 2010 thanks oleg thats what i thought wiring wise, but can only hear ch1 only not a mono sum of ch1 and ch2.. thanks again richard Quote
Andy P Posted November 19, 2010 Report Posted November 19, 2010 Yes my wiring/phase is all good, it's just the way it is. Quote
chris_bollard Posted November 19, 2010 Author Report Posted November 19, 2010 Thanks for all the responses BUT I have the older unit using 4 pin Lemo. So I'm afterpin details to go from 788t on TA3 to 4 pin lemo input. I was figuring I would adjust the 788 output to mic level but need to know what goes to which and if any filtering caps are required. Thanks Quote
Eric Toline Posted November 19, 2010 Report Posted November 19, 2010 Thanks for all the responses BUT I have the older unit using 4 pin Lemo. So I'm afterpin details to go from 788t on TA3 to 4 pin lemo input. I was figuring I would adjust the 788 output to mic level but need to know what goes to which and if any filtering caps are required. Thanks Ah, that's where the confusion is. In your 1st post you said TA5 not a TA3. That's why I asked if you had lav's wired for Lectro's TA5 connection. Eric Quote
chris_bollard Posted November 20, 2010 Author Report Posted November 20, 2010 Ah. Would be iPhone keypad or auto correct. Quote
