KGraham045 Posted March 20, 2015 Report Posted March 20, 2015 Anyone use The Cargo Cult "Conformalizer." I had a client change a picture lock and am looking for an easy way to fix the issue. Wondering if anyone has experience with this software? Quote
jozzafunk Posted March 20, 2015 Report Posted March 20, 2015 Yes I have used it - It's the standard here in NZ and very well regarded, and is a mature and well designed piece of software. it gets used on most of the big big budget films that do post here including PJ's and there's plenty of conforms on those.... Quote
KGraham045 Posted March 20, 2015 Author Report Posted March 20, 2015 So you would recommend it? Quote
nickreich Posted March 20, 2015 Report Posted March 20, 2015 If you want to find more about it online, worth knowing that the company recently changed it's name from Maggot Software to The Cargo Cult. If you search "Maggot Conformalizer" on duc.avid.com, gearslutz post forum etc you'll find heaps about it. Also look at EDILoad. Then there's Virtual Katy. The three current leaders in the field - and all three were written for or by people who worked on the Lord Of The Rings trilogy at one stage or another…. Quote
soundtrane Posted March 20, 2015 Report Posted March 20, 2015 very good. but EDLs have to be very good for it to work... Quote
Philip Perkins Posted March 20, 2015 Report Posted March 20, 2015 All of these apps assume that the picture cut is very together, which, I have found, means that you have to coach/supervise/harangue the people doing the exports for you. If you have your workflow down then these apps are God-like in how fast they can work and how much work they can save. But the homework has to be done..... I've found these things work out best on projects of scale, where there is an opportunity for workflow testing, and less well on one-off projects where there isn't much talking between depts and little if any testing. philp Quote
nickreich Posted March 20, 2015 Report Posted March 20, 2015 and if the picture editor is using Premiere Pro/CC at the moment, you might be in for a harder time as the EDL export function is broken as regards the way it writes audio track edits with samples instead of frames in the last part of every timecode number then leaves out the space that should follow. None of the Conform programs can read it. Quote
KGraham045 Posted March 20, 2015 Author Report Posted March 20, 2015 Thanks for the heads up on Premiere Pro Quote
thecargocult Posted March 22, 2015 Report Posted March 22, 2015 None of the Conform programs can read it. Conformalizer is fine with Video EDLs from Premiere. Audio EDLs I'm not sure but the Video EDL is the usual workflow. FWIW, the next version of Conformalzier also adds support for the XML files that Premiere creates. And there's now a document specifically for Premiere editors, explaining the export options: Linked here Justin Quote
nickreich Posted March 23, 2015 Report Posted March 23, 2015 Video track edits are ok in Premiere EDLs if that works for you, it's only the Audio tracks that are oddly formatted. The XML thing should fix it as some on the Adobe forum are sending an XML to Final Cut Pro and exporting an EDL from there with success. Quote
TDP Posted March 24, 2015 Report Posted March 24, 2015 Have used this several times on a few different projects - it saved my bacon (and time) every time I used it. Really easy. Nice interface. GREAT support from Justin. Quote
