Shawn D Posted September 13, 2016 Report Posted September 13, 2016 Hey all you brilliant electrical minds. I just purchased some Shure WL 184 hypercardioid lavs to use with my Lectrosonics SMQV transmitters. I replaced the connectors with TA5F and tried wiring them up based on Lectro's "Simple 3-wire 5V" diagram using a jumper across pins 2 and 4. It worked but it had some noticeable hiss and required a lot of gain (about 35 and up on the SMQV) and was pretty nasal and lacking in bass. Then I found a wiring method on the Shure website that said to try just wiring up pins 1, 2, and 3 to ground, bias V, and mic in respectively. This provides the mic with only 2 volts and not the 5V that the Lavs prefer. This also worked and sounded better with less hiss and a fuller sound than the Other wiring but it still requires similarly high gain. I'm wondering, does anyone have a better way to wire up these mics to Lectro TA5F's that maybe supplies them the full 5V and might require less transmitter gain? Thanks! Quote
LarryF Posted September 13, 2016 Report Posted September 13, 2016 1 hour ago, Shawn D said: Hey all you brilliant electrical minds. I just purchased some Shure WL 184 hypercardioid lavs to use with my Lectrosonics SMQV transmitters. I replaced the connectors with TA5F and tried wiring them up based on Lectro's "Simple 3-wire 5V" diagram using a jumper across pins 2 and 4. It worked but it had some noticeable hiss and required a lot of gain (about 35 and up on the SMQV) and was pretty nasal and lacking in bass. Then I found a wiring method on the Shure website that said to try just wiring up pins 1, 2, and 3 to ground, bias V, and mic in respectively. This provides the mic with only 2 volts and not the 5V that the Lavs prefer. This also worked and sounded better with less hiss and a fuller sound than the Other wiring but it still requires similarly high gain. I'm wondering, does anyone have a better way to wire up these mics to Lectro TA5F's that maybe supplies them the full 5V and might require less transmitter gain? Thanks! Hi Shawn, 1. Shield to pin 1 of the TA5. Also use lower fingers of the TA5 strain relief to grip the shield for RF grounding. Upper fingers grab insulation. 2. Red wire (Fet drain) to pin 3 of the TA5. 3. Black wire (Fet source) to pin 5. This puts a 2.7k source load to the mic. 4. Jump pin 2 (5 Volt) to pin 4 (bias set) to get the 4+ Volts setting of the Servo Bias. This all assumes the Shure schematic on their website is correct. Sometimes the manufacturers get cute and don't show a true schematic. If you need more gain, run the black wire to one end of a tiny 1k resistor. The other end of the resistor goes to pin 1 ground. As a test, you can try running the black wire to pin 1 for maximum gain. You can do all this testing without crimping the strain relief and without the black cover on the TA5F. You don't even need the metal locking section. All you really need is the plastic pin carrier with the wires attached and it goes on and off the pins in the SM very easily. It makes it easier to reconfigure the connections. Once it all sounds right, do a full assembly of the TA5F with the locking section, crimps and plastic strain relief. Best Regards, Larry F Quote
Shawn D Posted September 14, 2016 Author Report Posted September 14, 2016 Larry, thank you so much! Quote
LarryF Posted September 16, 2016 Report Posted September 16, 2016 Hi Shawn, Have you had a chance to try it yet? Regards, LEF Quote
Shawn D Posted September 22, 2016 Author Report Posted September 22, 2016 Larry, The wiring prescribed by you seems to be the same as the fig11 on the Lectro website "simple 5v 3-wire mic" which I tested first. That configuration gave me about 3-6dB less signal that the wiring on the Shure customer help forum (pins 1, 2, and 3 to ground, bias V, and mic in respectively). However I just tried what you recommended and to achieve max gain combined the black wire and shield at pin 1 and that gave me 6dB more gain than the Shure wiring. I'm quite happy with this, thanks Larry! Quote
LarryF Posted September 22, 2016 Report Posted September 22, 2016 Hi Shawn, The Shure mic may have an internal resistor not shown on the schematic. Jumping pin2 to pin4 gives a full 4+ Volts on the mic rather than 2 Volts as in the Shure recommended wiring. Glad we were able to fumble our way to a solution. Best Regards, Larry Fisher Quote
Shawn D Posted January 23, 2017 Author Report Posted January 23, 2017 Hey Larry, I just did a job where we used these Shure directional lavs again and I rented an SRb and LMb combo for an extra channel. I ran into a very quiet signal from the lav even when the gain was cranked to it's max gain, 44 I believe. It was very noisy and such a low output that I even turned to using "mic" preamp settings on my Nomad to give it even more preamp gain so it would be usable in the show. I tried all 6 of my Shure 184 lavs on this TX and while some were a bit louder than others, all were basically unusably quiet. It appears that perhaps the input stage on the LMb is different to the SMQV's that I was using without issue. My questions are: 1. Is the input stage wired or setup differently on the LMb than on the SMQV? Is this like the servo/simple wiring incompatibilities? 2. Are any of the other Lectrosonics TX's (LT, SSM, UM400) also wired in a way that would be incompatible with my current wiring for my Shure 184's that currently works with my SMQV's? I'm considering getting an SSM but that would require a lemo-ta5m adapter and this seems like it could also pose a problem. Thanks! Quote
JimKeaney Posted March 7, 2020 Report Posted March 7, 2020 On 9/13/2016 at 3:43 PM, LarryF said: Hi Shawn, 1. Shield to pin 1 of the TA5. Also use lower fingers of the TA5 strain relief to grip the shield for RF grounding. Upper fingers grab insulation. 2. Red wire (Fet drain) to pin 3 of the TA5. 3. Black wire (Fet source) to pin 5. This puts a 2.7k source load to the mic. 4. Jump pin 2 (5 Volt) to pin 4 (bias set) to get the 4+ Volts setting of the Servo Bias. This all assumes the Shure schematic on their website is correct. Sometimes the manufacturers get cute and don't show a true schematic. If you need more gain, run the black wire to one end of a tiny 1k resistor. The other end of the resistor goes to pin 1 ground. As a test, you can try running the black wire to pin 1 for maximum gain. You can do all this testing without crimping the strain relief and without the black cover on the TA5F. You don't even need the metal locking section. All you really need is the plastic pin carrier with the wires attached and it goes on and off the pins in the SM very easily. It makes it easier to reconfigure the connections. Once it all sounds right, do a full assembly of the TA5F with the locking section, crimps and plastic strain relief. Best Regards, Larry F Hi Larry, I have found myself wiring some Shure 184's for Lectrosonics TA5. Can you clarify if when you suggested running the black AUDIO wire to pin 1/Ground without the resistor, you mean **instead** of going to Pin 5 at all? Or... Black wire to Pin 5 + Ground? Thanks! -Jim Quote
Indeliblesound Posted April 24, 2025 Report Posted April 24, 2025 Reviving an old thread! Rewiring Shure instrument mics (PGA98H) for SMQV/SMDWBs, removing TA4F replacing with TA5F. Shure currently wired for condensor: - audio lead (black) to pins 3 and 4 - bias lead (red) to pin 2 - shield to pin 1 and connector body (use cable clamp insert piece as the connector body terminal) If I follow Larry's instructions and I only go to #3 and skip #4, that gives me universal wiring instead of servo? Quote
LarryF Posted April 24, 2025 Report Posted April 24, 2025 I couldn't find a schematic for the mic, even on the Shure site. Wiring 2 jumped to 4 will increase the pin 3 bias to 5 Volts equivalent, which might give you more headroom. I am kind of in the dark without a schematic. LEF Quote
Indeliblesound Posted April 24, 2025 Report Posted April 24, 2025 Thanks Larry! This was all I could find on Shure's site: https://service.shure.com/s/article/pin-out-for-shure-bodypack-transmitters-and-preamps-ta4m-ta4f?language=en_US®ion=en-US Towards the bottom is what I had cut/paste and can confirm by opening up the connector it is wired this way on the PGA98H. I wired shield to P1/Strain, red to P3, black to P5 and get a clean signal(not case tested on instrument). But if P2 to P4 gives me more headroom then I would prefer that. Wiring brass instruments marching so mics peak at 130db don't want to sacrifice any of that. If it doesn't matter it'll save us time since we are doing 16 mics total! Quote
