Make it yourself, or get your dealer to make it for you - it's going to be a custom cable either way. If you make it yourself, connect the left and right ouputs of the TA3 (not sure of the pin assignments but probably 2 and 3) to the ring on the 3.5mm, and the ground to both the tip and ring.
the input of senny is -10 db unbulanced on the ring, Tip is mic unbanced input.
<So you have to put two resistor onthe pin 2 an 3 on the ta3
pin 2 resistor reistor pin 3
betweeen the two rewsistor you have the mono to connect at the ring
shold be 10khom
sorry for my bloody english...
"the input of senny is -10 db unbulanced on the ring, Tip is mic unbanced input."
- Yes, the input of Sennheiser G2/3 SK-100 body pack transmitter will accept a -10dB nominal signal unbalanced to the ring connector,.. when configured for line level, the tip must be tied to the sleeve/ground
Has anyone thought to build a cable with in line variable attenuation or switching of ring to sleeve, in the case of the sennheiser units, and panning?
I can think of a dozen occasions, where the panning option would have been convenient. I opted to instead build a TA3 to 3.5mm stereo splitter cable and swap out when needed. I couldn't find a small enough 3 way switch, at the time.
  • 2 years later...
Resurrecting this wiring thread as I'm currently trying to cheap out on a second private comms feed that's bag based.
Using a G3 transmitter with IEM RX for my boom op anyway, feeding the 788T's slate mic to both the main comteks and his G3. Now I want to add another mic that feeds only the boom op's G3.
A cheap solution - if it works - would be connecting his feed to the ring and a mic to the tip of the G3 input.
Anybody tried this? Is it worth a few minutes of soldering?
I have read these threads that also have significant info about G3 wiring but not about double use:
Another cheap solution is:
send mic level out of the 788T output, and passively sum them.
I would like to not add another box that needs powering.
  • 1 year later...
The link seems to be dead. I'm making a standard TRS jack to summed G3 line level input. Have any of you had any luck with this wiring without any in line pading?
Standard stereo source:
  • Tip - hot
  • Ring - cold
  • Sleeve - ground
G3 line input:
  • Tip - ground
  • Ring - hot+cold
  • Sleeve - ground
Wait... what? You want to feed a 'L' signal to go out to boom op, and a 'R' signal to go to client? I don't think you can have a G3 transmitter (belt pack) fed a stereo signal and have it transmit left to an IEM for director and right to boom op IEM. I don't think they work that way. The base station has a proper L/R input and can send a stereo signal, and it is possible then to have one set of IEMs receive the L and another set receive the R. Lots of people here in the UK have that setup. But I don't believe the belt pack has that option. It isn't "stereo", it's balanced mono. I'd love to be corrected if I am wrong.
You are absolutely correct RP. The SK series transmitters are mono, however they can feed the IEMs receiver a mono signal and the HDX compander (noise reduction) is compatible. In order to do what the OP desires, a complete SW300 system would be needed, which has separate L&R inputs on the x-mitter and the receivers allow the user to select, stereo or a mix or the two, for instance a vocal / instrument mix.
 If feeding an G2/3 SK100 series bodypack transmitter, 3.5mm plug's the ring terminal is line level, though it will likely distort with full +4dB program material, so a 10 or so dB L-pad is recommended.  The SR300 IEM transmitter handles inputs to 22dBu.
