LarryF Posted September 6, 2013 Report Posted September 6, 2013 I thought I'd start a new thread so it would be easy to find and be more easily searchable. So far the Quantum alkaline AA's are looking very good; 2.2 Ah for the Quantum versus 1.2 Ah for a Panasonic AA at a heavy drain (SM transmitter) of 400 mAh. That's an 83% improvement. (!) The second run is at 500 mAh and I got 2 Ah. This is an SM drain toward the end of the battery life. Pretty impressive. I still have to run the Panasonic at 500 mAh but it will probably only make 1 Ah. Adding to my original post, the Panasonic at 500 mAh made 1.1 Ah while the Quantum made 2.0 Ah for an 82% advantage again. It looks like the Quantum claims are very real. In an SM at 100 mW, the Panasonics ran for 97 minutes until the SM shutdown. The Quantums ran for 175 minutes. This is an advantage of 80%, in line with the precision battery load. I hope Duracell doesn't go nuts with the pricing. Best Regards, Larry Fisher Lectrosonics Quote
studiomprd Posted September 6, 2013 Report Posted September 6, 2013 (edited) " I hope Duracell doesn't go nuts with the pricing. " so far, typically, they are not 83% more costly Home Depot has 8 pack of AA or AAA $7.48 8-pack of E2 (Li) AA $17.97 Walgreens had Quantum on special: AA /12pk reg $15.99 sale: $9.49 Edited September 6, 2013 by studiomprd Quote
LarryF Posted September 6, 2013 Author Report Posted September 6, 2013 " I hope Duracell doesn't go nuts with the pricing. " so far, typically, they are not 83% more costly Home Depot has 8 pack of AA or AAA $7.48 Hi Mike, Lithium batteries might be competitive on a power versus cost basis. I assume lithium AA's are costing about $1.50 to 1.75 in bulk.(?) I would hope Duracell would put these between alkalines and lithiums for pricing. Whoops, I just saw the rest of your post at $1/ea at Home Despot. I assume the price will drop after they aren't the new shiny thing. One minor negative; they are heavier than lithiums. Best, Larry F Lectro Quote
studiomprd Posted September 6, 2013 Report Posted September 6, 2013 I added a bit more info to my earlier post on prices... AA and AAA seem to typically be the same price, and at Walgreens they had the regular coppertops at 16/$16.99 regular, on sale for $9.50 Quote
Angelo Waldron Posted September 6, 2013 Report Posted September 6, 2013 Thanks for testing. Costco..... 30 for $18. http://www2.costco.com/Browse/Product.aspx?Prodid=11900108&search=AA+Battery&Mo=4&cm_re=1_en-_-Top_Left_Nav-_-Top_search&lang=en-US&Nr=P_CatalogName:BD_823&Sp=S&N=5000046&whse=BD_823&Dx=mode+matchallpartial&Ntk=Text_Search&Dr=P_CatalogName:BD_823&Ne=4000000&D=AA+Battery&Ntt=AA+Battery&No=2&Ntx=mode+matchallpartial&Nty=1&topnav=bdoff&s=1 Quote
LarryF Posted September 6, 2013 Author Report Posted September 6, 2013 I added to my original post but the Panasonic at 500 mAh made 1.1 Ah while the Quantums made 2.0 Ah for an 82% advantage again. It looks like the Quantum claims are very real. In an SM at 100 mW, the Panasonics ran for 97 minutes until the SM shutdown. The Quantums ran for 175 minutes. This is an advantage of 80%, in line with the precision battery load. Best, Larry F Lectro Quote
John Blankenship Posted September 7, 2013 Report Posted September 7, 2013 How do they bounce? Nice chuckle. Quote
Marc Wielage Posted September 7, 2013 Report Posted September 7, 2013 I tried the bounce test on some AA's at my house yesterday, and couldn't get it to work. I suspect the heat! (100+ in Northridge, CA this week.) The Quantum batteries sound very good for some purposes, basically like a "more perfected" Alkaline chemistry to me. Dollar-for-dollar, it sounds like they work out to about the same as Lithium. 5 hours for a Lithium AA in an SMa at about $1.75; 3 hours for a Quantum in an SMa at about 90 cents. Quote
LarryF Posted September 7, 2013 Author Report Posted September 7, 2013 How do they bounce? sb So far, the dead ones bounce three or four times before falling over and the unused ones hit the table with a thud and not even one bounce.Cheers, Larry F Quote
LarryF Posted September 7, 2013 Author Report Posted September 7, 2013 I tried the bounce test on some AA's at my house yesterday, and couldn't get it to work. I suspect the heat! (100+ in Northridge, CA this week.) The Quantum batteries sound very good for some purposes, basically like a "more perfected" Alkaline chemistry to me. Dollar-for-dollar, it sounds like they work out to about the same as Lithium. 5 hours for a Lithium AA in an SMa at about $1.75; 3 hours for a Quantum in an SMa at about 90 cents. Hi Marc,Good cost comparison. In the SMQv, a pair of the Quantums (Quanta?) might may make an "all day" battery setup for half the cost of the Lithiums. We will try a comparison run down in the same SMQv transmitter next Monday and Tuesday. Best Regards, Larry F Lectro Quote
Jack Norflus Posted September 7, 2013 Report Posted September 7, 2013 Just picked up a 30 pack of the quantum's at Costco. They are on sale for $12.99 they came out to just .43 cents a battery. Quote
LarryF Posted September 7, 2013 Author Report Posted September 7, 2013 Just picked up a 30 pack of the quantum's at Costco. They are on sale for $12.99 they came out to just .43 cents a battery. Hi Jack, That would make them extremely cost effective. Best, Larry F Quote
Jack Norflus Posted September 7, 2013 Report Posted September 7, 2013 Especially since I usually pay 30 something cents for ordinary alkaline. Larry just curious in your tests so far do the quantums drop in charge more like an ordinary alkaline or more like a lithium? Quote
LarryF Posted September 7, 2013 Author Report Posted September 7, 2013 Hi Jack, They drop like an alkaline. At any point on the falling voltage line, they have higher voltage. It's as if they are seeing half the load. Or another way of describing it, is that a single Quantum looks about like two Panasonics in parallel under the relatively high current draw in my tests. By the way, the Panasonics are a perfectly good battery and are equal to any other standard major brand battery, with banging Bunnies or not. (I don't want Panasonic sending a late night ninja squad to my bedroom.) Best, Larry F Lectro Quote
Marc Wielage Posted September 8, 2013 Report Posted September 8, 2013 Just picked up a 30 pack of the quantum's at Costco. They are on sale for $12.99 they came out to just .43 cents a battery. That's an unbeatable price! Quote
LarryF Posted September 11, 2013 Author Report Posted September 11, 2013 OK, here is the last test for awhile on the Quantum batteries. We loaded some into an SMQv at 100 mW and they ran for 8 hours and 56 minutes (8.93 hours) and the Panasonics ran for 6 hours and 16 minutes (6.27 hours) or a 42% advantage to the Quantums. So under light loads, the Quantums have a 45% advantage, using their manufacturer's rating at 3.92 Ah rating versus a standard alkaline at 2.7 Ah. Under a moderate load using two batteries (SMQv at 100 mW) they have the same 42% advantage and under a heavy load using a single battery (SMv at 100 mW) they have an 80% advantage. These numbers are in line with the battery rated light load capacity (+45%) and the heavy load using the precision battery load (+80%) at 400 and 500 mA. In conclusion, these batteries at a little more cost than a standard alkaline would be a good buy. Or if you need a running time between a standard alkaline and a pricey lithium. 1. Total running times can be moderately extended using the sleep mode on the transmitters to give the batteries a rest. 2. Cold weather is not a friend of alkaline batteries. Go with NiMh or lithiums. Best Regards, Larry Fisher Lectrosonics Quote
Derek H Posted September 11, 2013 Report Posted September 11, 2013 Thanks for the thorough results Larry! A follow-up question: Do the low-battery indicators work accurately at the transmitter and receiver for this battery? I assume one would use the alkaline setting. And another: I'm always wary with alkalines of acid leakage. Is there any way to tell if the risk is the same or better with the Quantums? Thanks again. Quote
LarryF Posted September 11, 2013 Author Report Posted September 11, 2013 Thanks for the thorough results Larry! A follow-up question: Do the low-battery indicators work accurately at the transmitter and receiver for this battery? I assume one would use the alkaline setting. And another: I'm always wary with alkalines of acid leakage. Is there any way to tell if the risk is the same or better with the Quantums? Thanks again. Hi Derek, Looking at the discharge curves, they look the same except the voltage falls at a slower rate, i.e., the Quantums just look like a 40 to 80% bigger battery. As far as electrolyte leakage, we won't know till some of these batteries get to be ancient. The use by date is 2023 which indicates they think they will last for awhile. Incidentally, it isn't "acid" leakage but a "base" (opposite of acid) potassium hydroxide, similar to lye (sodium hydroxide). I only mention that because you would want to neutralize it with a mild acid like vinegar or simply lots of water. Potassium hydroxide will etch/and/or eat aluminum such as our battery compartments much faster than an acid. Best Regards, Larry Fisher Lectrosonics Quote
studiomprd Posted September 11, 2013 Report Posted September 11, 2013 " Incidentally, it isn't "acid" leakage but a "base" (opposite of acid) " aka: alkaline! hmmm... just thinking... Lead Acid batteries have acid ? and... hold the presses... Nickel Cadmium batteries contain... Nickel and Cadmium..? I think I'm on to something... Quote
Jack Norflus Posted September 11, 2013 Report Posted September 11, 2013 Cold weather is not a friend of alkaline batteries. Go with NiMh or lithiums. You mean operating in the cold. I was always under the impression that cold extends the shelf life of alkaline batteries. My grandmother used to store her batteries in the refrigerator. Quote
studiomprd Posted September 11, 2013 Report Posted September 11, 2013 " My grandmother used to store her batteries in the refrigerator. " exactly, cold slows down the chemical reactions. and I'm guessing she was originally storing Carbon-Zinc batteries... . Quote
LarryF Posted September 11, 2013 Author Report Posted September 11, 2013 You mean operating in the cold. I was always under the impression that cold extends the shelf life of alkaline batteries. My grandmother used to store her batteries in the refrigerator. Hi Jack, As Mike said, cold slows down the deterioration of batteries but it also slows them down so much, they don't work well. Modern alkaline batteries have such a long shelf life, it doesn't do as much good to store them in a refrigerator. If they are frozen, they can lose their seals due to hardening in the cold. Best, Larry F Lectro p.s. Potassium hydroxide (dry) is a base and in an aqueous solution, as in a battery, the gel is alkaline (high Ph). "Base" and "alkaline" are loosely defined, however, and one can wander over into the definition of the other. Other oddness: NiMh and NiCd also contain potassium hydroxide as a gel electrolyte but aren't referred to as alkaline. Quote
Mark Bahner Posted December 15, 2019 Report Posted December 15, 2019 Thanks so much for this test data on Quantum AA batteries! It was just what I was looking for before buying them. Mark B. Quote
