Hey Guys,
Trying to find some info on the Sennheiser MZG 8000 swivel module for the 8xxx series of microphones.
Anyone have/used one before?  I've been looking for a Schoeps gvc/41 replacement for a while and was thinking the 8050 with this swivel might be a good option.  I was mainly wondering about it's range of swivel compared to a GVC, as well as the overall reliability of the 8xxx series.
Thanks,
Joe
Hey Guys,
Thanks,
Joe
I've got a couple but have only had them for a couple of weeks (arrived just *after* the low loader day...)
They work- will swivel to maybe a bit more than 90degrees. Possibly not quite as far as the schoeps. I don't think there's any mechanical issues with the 8000 series but they did change the PCB design earlier this year to get around the grounding/noise issue
Thanks for the reply.  Good to know about the PCB change.  That noise was the only finicky thing I heard about the 8xxx series and I'm glad they fixed it.  Just to confirm: does the MZG swivel both ways, or only in one direction?
Is there a way to visually differentiate an older modelmodel to one with a newer upgraded PCB swivel??
There's no difference in the swivels (they're just a mechanical and electrical connection), the newer 8000 series mics have a darker band at the screw connector with the MZX XLR adapter
I have a couple 8050s and use to own 3 8060's. My understanding was the 8060 was the only mic with the grounding issue. I ran into it with all 3 8060s, but neither 8050. One 8050 is old (with dark band), one is newer (with gold band).
I've had the swivel joint for quite a while. No issues.
J
no, I had the problem with a couple of 8020 Omnis, I know several others who did too, with 8020s and 8040s - so probably random mics across the whole range were affected.
