JonPaulSound Posted August 16, 2016 Report Posted August 16, 2016 I'm having an issue getting time code from my zaxcom ERX into an atomos Flame. The flame has the updated software to sync thru the BNC sync connector. When jamming the flame claims the time code is a different frame rate. Both are set at 23.98. The flame jams fine from an F55. Time code is fed from my 788t thru a trx900CL shows up fine at the display on the ERX. Any thoughts ? Quote
Jack Norflus Posted August 16, 2016 Report Posted August 16, 2016 Have you tried to adjust the tc output level? Quote
JonPaulSound Posted August 16, 2016 Author Report Posted August 16, 2016 yes the atomos saw the code it just said it was unrecognizable frame rate and would not jam code Quote
John Blankenship Posted August 16, 2016 Report Posted August 16, 2016 Have you tried both Auto Frame Rate and setting it manually on the ERX? Have you tried jamming the Flame directly out of the 788T? Have you tried jamming it directly out of the TRX900CL? What are the results for each? Quote
JonPaulSound Posted August 16, 2016 Author Report Posted August 16, 2016 It jams directly out of the 788 . I also tried turning off the auto tc function on the zaxcom and it did not help. I will try other options when I get time to trouble shoot more. The flame is new to the DP and he is not quite up to speed with it either. More to come.... Quote
glenn Posted August 16, 2016 Report Posted August 16, 2016 Try a even frame rate like 30DF or 30 NDF and see if that makes a difference. You would only need to set the ERX to 30 the CL can stay at 29.97 for the test. Glenn Quote
JonPaulSound Posted August 17, 2016 Author Report Posted August 17, 2016 So it appears to have been a multi level issue. 1st. The a7sii that was feeding the flame only feeds 59.94 out of the hdmi output according to the DP. So he was telling me 23.98 and I was matching that with the erx. Because it was actually 59.94 into the flame it would not jam to 23.98. Once we figured that out I switched to 29.97 and it would jam temporarily and then lose code just as quickly. After turning off auto TC function on the Erx it held code, all though if the cable was bumped on the erx it will still lose code temporarily and the rejam almost as quick. Not sure if this is a bad cable, bad jack on my erx or just the limitations of a 1/8" mini connection. I have a new cable on the way and will check with a different erx as soon as I get a chance. Does anyone make a locking 1/8" to bnc and will it lock down on the ERXtc3 ? Thanks for the help ! The unrecognizable frame rate warning on the flame was when I was still feeding 23.98 but had turned off the auto TC feature. Thanks again. ! Quote
Tom Visser Posted August 17, 2016 Report Posted August 17, 2016 The DP should set the HDMI output resolution to 1080i (likely has it set to 1080p) and in HDMI cadence, set for progressive with 3:2 pulldown for 23.98 recording framerate. Then in the Flame, it should be able to be set for input 3:2 detection to record a progressive 23.98 file. Quote
John Blankenship Posted August 17, 2016 Report Posted August 17, 2016 Another reminder that "Time Base," "Frame Rate," and "Time Code" are three different things. On some cameras, such as the Alexa, there's also a "Sensor Rate." Quote
