Hey guys, I switch between Lectro and Zax/Shure fairly often and have my lavs wired with a microdot connector so I can switch connectors as needed. Occasionally the connector will come loose, particularly for ankle rigs for some reason, and need tightening throughout the day.
Any tips for securing the connector more securely?
That's strange, I've never had a microdot adapter loosen.
Although I've discovered old versions with lemo adapter have an o ring and new ones don't.
Maybe it has something to do with this and you have old microdot lemo adapters that are missing the o ring?
you could try wrapping some ptfe thread seal tape around the outside of the connector. It can be relatively easily removed and leaves no residue.
  • 2 weeks later...
21 minutes ago, thesound said:
PTFE thread seal tape is a good idea, as long as the threads don’t have to conduct electricity.…
The threads are the mic ground, so probably not a good idea
Maybe a tiny dab of loctite purple (lowest strength) would work… but I’d test that on a mic and adapter that you don’t mind glueing if it is too strong
