Mattias Larsen Posted May 9 Report Share Posted May 9 Heya! I guess most of you are familiar with mki and mkii of this camera. Its straight forward to slap on a TC box, set TC to in, preset, free run and its all thats needed to run smoothly. I could not get it to work on the mark iii today. Has anyone got a similair experience or got any 'gotchas' they could share? Only thing I can think of in hindsight was if the cable was broken or if there was a monitor setting that I didn't catch, but I had the impression that it didn't catch the TC at all. Quote Link to comment Share on other sites More sharing options...
codyman Posted May 10 Report Share Posted May 10 Check the frame rate on the camera. Quote Link to comment Share on other sites More sharing options...
edward chick Posted May 10 Report Share Posted May 10 What codyman stated would be my guess. Check your frame rates @ camera and mixer/recorder. Cables would be next to check in the chain of sync . I’ve had cables go bad during the afternoon, even though they worked fine in the morning and on several jobs before the job they crapped out on. Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted May 10 Report Share Posted May 10 One gotcha could be the one where the “project setting “ is different than the TC setting. Another is if the frame rate is set to hi speed (like 48 frames or higher). Sorry of those seem too obvious, but sometimes in the heat of the battle…. Quote Link to comment Share on other sites More sharing options...
Mattias Larsen Posted May 10 Author Report Share Posted May 10 Thank you for all the input people, honestly! I remember with Panasonic that I often had to make sure the camera was not set to variable framerate, never experienced it with the canons before, but something like that is a very realistic possibility that it could be related to. Will read up on the manual about high speed/variable framerate/project framerate. Quote Link to comment Share on other sites More sharing options...
Mattias Larsen Posted May 11 Author Report Share Posted May 11 Prepared to look at codec/project settings and what not today. And it simply jammed just fine with same tentacle, same cable etc. Difference was that we shot 23.98 instead of 29.97 as we did two days ago. So I am not much wiser, but thought I would give it an update. Quote Link to comment Share on other sites More sharing options...
Ontariosound Posted May 12 Report Share Posted May 12 Probably not the situation here, but all the C300 Mk II's that I tried with my pair of Zaxcom RX 200's did not lock 100% with the super cool Timecode out BNC of these great sounding hops. They EXT lock icon bounced back and forth. Regardless of output level settings. Sony and Arri cameras never have a problem. Quote Link to comment Share on other sites More sharing options...
